Salta al contenuto principale
Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement
Cosa ti serve
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: passo 1, immagine 1 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: passo 1, immagine 2 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Power and Telephone Cords: passo 1, immagine 3 di 3
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Removing Screws to Base Plate: passo 2, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: passo 3, immagine 1 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: passo 3, immagine 2 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Cordless Phone Base Replacement, Remove Bottom Plate from Base: passo 3, immagine 3 di 3
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 6
Tutti i Tempi: 372
