Salta al contenuto principale
Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement
Cosa ti serve
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: passo 1, immagine 1 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: passo 1, immagine 2 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Power and Telephone Cords: passo 1, immagine 3 di 3
    • To disconnect the phone cord, squeeze the tab against the connector and pull the cord away from the telephone-line-in-jack.
    • To disconnect the power cord, grasp the end and pull back and away until it is disconnected.
    • Once disconnected remove each cord from its track.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Screws to Base Plate: passo 2, immagine 1 di 1
    • Using a Phillips #00 screwdriver, remove the six 7mm screws from the base plate.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: passo 3, immagine 1 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: passo 3, immagine 2 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Remove Bottom Plate from Base: passo 3, immagine 3 di 3
    • With the base turned upside down, grasp the edges of the base plate and gently lift from the rest of the base.
    • Two wires lead from the motherboard to the charger plate, so the two parts cannot be completely separated without further steps.
  4. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing the Screws from the Charger Plate: passo 4, immagine 1 di 1
    • Use a Phillips #00 screwdriver to remove the two 5mm screws from the metal plate.
  5. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing the Plate: passo 5, immagine 1 di 1
    • Grip the metal plate and pull towards you.
    • You may need to wiggle the plate back and forth gently to loosen it from its housing.
  6. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Screw from Base Cover: passo 6, immagine 1 di 1
    • Use the Philips #00 screwdriver to remove the four 6mm screws from the base cover.
  7. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Separating Charge Plate from Base Cover: passo 7, immagine 1 di 1
    • Gently pull the charge plate away from the rest of the base and separate the two pieces of the charge plate.
  8. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Glue from Wires: passo 8, immagine 1 di 2 Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Removing Glue from Wires: passo 8, immagine 2 di 2
    • Use the spudger to gently scrape the glue away from the wire connections.
    • If the spudger is not adequate, try using the tweezers to pull the glue away before scraping.
  9. Polyconcept 900-MHz Retro Cordless Telephone Device Charger Plate Replacement, Desoldering the Wire Connections: passo 9, immagine 1 di 1
    • Use the soldering station to desolder the wire connections.
    • For further instructions on using the soldering station click here.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 1
Tutti i Tempi: 176
