Salta al contenuto principale
Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: passo 1, immagine 1 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: passo 1, immagine 2 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Cover: passo 1, immagine 3 di 3
    • Hold the mouthpiece of the handset and locate the lock-unlock text.
    • Twist the battery cover counterclockwise from the "lock" to the "unlock" position.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: passo 2, immagine 1 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: passo 2, immagine 2 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Disconnecting the Battery Wire: passo 2, immagine 3 di 3
    • To disconnect the battery pack wire from the phone, squeeze the tab against the connector and pull connector straight up from the socket.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: passo 3, immagine 1 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: passo 3, immagine 2 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Battery Replacement, Removing the Battery Pack: passo 3, immagine 3 di 3
    • Pull the battery from the battery compartment.
    • You may need to gently wiggle the battery back and forth in its compartment to help loosen it.
Conclusione
Altre 2 persone hanno completato questa guida.
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 13
Tutti i Tempi: 883
