Salta al contenuto principale
Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement
Cosa ti serve
  1. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: passo 1, immagine 1 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: passo 1, immagine 2 di 3 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Screw: passo 1, immagine 3 di 3
    • Inside the base cover, locate the screw holding the antenna in place and use a Philips #00 screwdriver to remove the 6mm screw.
  2. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Foot: passo 2, immagine 1 di 2 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna Foot: passo 2, immagine 2 di 2
    • Grasp the plastic antenna foot and pull toward you.
  3. Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna: passo 3, immagine 1 di 2 Polyconcept 900-MHz Retro Cordless Telephone Device Antenna Replacement, Removing the Antenna: passo 3, immagine 2 di 2
    • Pull antenna from the top side of the phone base cover.
    • It helps if you gently wiggle the antenna back and forth to loosen the clips.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 13
Tutti i Tempi: 359
