Salta al contenuto principale
Polycom SoundStation Button Pad Replacement
Cosa ti serve
  1. Polycom SoundStation Button Pad Replacement, Back Housing: passo 1, immagine 1 di 1
    • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
    • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
  2. Polycom SoundStation Button Pad Replacement: passo 2, immagine 1 di 2 Polycom SoundStation Button Pad Replacement: passo 2, immagine 2 di 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
  3. Polycom SoundStation Button Pad Replacement, Button Pad: passo 3, immagine 1 di 1
    • Remove the rubber keyboard.
Conclusione
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 7
Tutti i Tempi: 924
