Salta al contenuto principale
Polycom SoundStation Back Housing Replacement
Cosa ti serve
  1. Polycom SoundStation Back Housing Replacement, Back Housing: passo 1, immagine 1 di 1
    • Flip the device over. Using a Phillips #00 screwdriver, remove the black 10mm screw on each three legs of the phone.
    • Using a Phillips #00 screwdriver, remove the two silver 7mm screws as pictured.
  2. Polycom SoundStation Back Housing Replacement: passo 2, immagine 1 di 2 Polycom SoundStation Back Housing Replacement: passo 2, immagine 2 di 2
    • Gently lift and separate the back housing from the rest of the device. Now you've got the back housing off!
Conclusione
Un commento
thanks for this - the 7mm were under footpads so I couldn’t see them. cover now off, keyboard dried of coffee and working fine again!!
J M - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 16
Tutti i Tempi: 1,165
