Introduzione
This guide will show you how to swap out the bluetooth sensor in your soundbar. Keep in mind this is a fragile cable that can easily be broken. It must be handled with care.
Cosa ti serve
To reveal the control button, first, carefully remove the front cover of the Sound Bar.
Use the plastic iFixit opening tool to lift up the front surface. Insert the tool between the cover and the body to open it.
After the cover is fully removed, it will be able to see the interior speaker.
Carefully unscrew all 16 screws to release the panel.
