Salta al contenuto principale
Polaroid i533 Zoom Lens Replacement
Cosa ti serve
  1. Polaroid i533 Zoom Lens Replacement, Zoom Lens: passo 1, immagine 1 di 3 Polaroid i533 Zoom Lens Replacement, Zoom Lens: passo 1, immagine 2 di 3 Polaroid i533 Zoom Lens Replacement, Zoom Lens: passo 1, immagine 3 di 3
    • Use a Phillips #00 driver to remove four screws (3mm) on the left side of the camera. Keep all screws for reassembly.
    • Directly on the bottom of the camera there are 3 screws, unscrew all with a Phillips #00 driver.
    • Unscrew two screws on the right side of the camera with a Phillips #00 driver.
  2. Polaroid i533 Zoom Lens Replacement, Opening back cover: passo 2, immagine 1 di 2 Polaroid i533 Zoom Lens Replacement, Opening back cover: passo 2, immagine 2 di 2
    • Locate the battery door on the bottom of the camera. Then slide the battery door open using the iFixit opening tool.
    • Gently open the back cover of camera.
    • Do not pull the cover off completely, because it is still attached to the logic board.
  3. Polaroid i533 Zoom Lens Replacement: passo 3, immagine 1 di 3 Polaroid i533 Zoom Lens Replacement: passo 3, immagine 2 di 3 Polaroid i533 Zoom Lens Replacement: passo 3, immagine 3 di 3
    • Locate where the LCD screen ribbon is attached to the logic board.
    • Using the ifixit opening tool, push the black tab connecting the LCD screen ribbon to the logic board away from you.
    • Gently pull the ribbon away from the logic board with thumb and index fingers.
  4. Polaroid i533 Zoom Lens Replacement, Removing screws on logic board: passo 4, immagine 1 di 2 Polaroid i533 Zoom Lens Replacement, Removing screws on logic board: passo 4, immagine 2 di 2
    • Using the Phillips #00 screwdriver, unscrew and remove the (3mm) screw on the bottom of the logic board above the tripod mount. Keep the screw for reassembly.
    • Gently pull the front of the case off.
  5. Polaroid i533 Zoom Lens Replacement: passo 5, immagine 1 di 2 Polaroid i533 Zoom Lens Replacement: passo 5, immagine 2 di 2
    • Locate the black patch covering the ribbon that connects the zoom lens to the logic board.
    • Carefully remove the black patch using tweezers.
  6. Polaroid i533 Zoom Lens Replacement, Removing zoom lens ribbon: passo 6, immagine 1 di 2 Polaroid i533 Zoom Lens Replacement, Removing zoom lens ribbon: passo 6, immagine 2 di 2
    • Using tweezers gently lift the black tab that holds the zoom lens ribbon in place.
    • Gently remove the zoom lens ribbon.
  7. Polaroid i533 Zoom Lens Replacement: passo 7, immagine 1 di 2 Polaroid i533 Zoom Lens Replacement: passo 7, immagine 2 di 2
    • Use the Phillips #00 screwdriver and unscrew then remove the three (3mm) screws shown on the back of the logic board.
    • On the left side of the logic board use the same screwdriver. Unscrew and remove the 3mm screw. Keep all screws for reassembly.
  8. Polaroid i533 Zoom Lens Replacement: passo 8, immagine 1 di 2 Polaroid i533 Zoom Lens Replacement: passo 8, immagine 2 di 2
    • It is now safe for you to remove the zoom lens.
    • To reassemble the device, follow these steps in reverse.
Conclusione
To reassemble your device, follow these steps in reverse order.
Aric Champagne
Membro da: 06/24/10
18 Reputazione
1 Guida realizzata
Cal Poly, Team 3-4, Johann Summer 2010 Membro di Cal Poly, Team 3-4, Johann Summer 2010
CPSU-JOHANN-R10S3G4
4 Membri
8 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 11
Tutti i Tempi: 2,677
