Salta al contenuto principale
Polaroid a520 LCD Screen Replacement
Cosa ti serve
  1. Polaroid a520 LCD Screen Replacement, Battery: passo 1, immagine 1 di 2 Polaroid a520 LCD Screen Replacement, Battery: passo 1, immagine 2 di 2
    • Place your thumb on the battery cover and push left towards the arrow.
    • The cover will release and pop open.
  2. Polaroid a520 LCD Screen Replacement: passo 2, immagine 1 di 1
    • Remove the batteries from the camera.
  3. Polaroid a520 LCD Screen Replacement, Casing: passo 3, immagine 1 di 1
    • Remove four 3 mm screws on the right side of the camera using a Phillips #1 screwdriver.
    • This will release the front and back casings.
  4. Polaroid a520 LCD Screen Replacement: passo 4, immagine 1 di 1
    • Use your nail or a flat object to pry up the edge of the front casing. Push the casing up and back.
    • Repeat this step for the back casing.
  5. Polaroid a520 LCD Screen Replacement, LCD Screen: passo 5, immagine 1 di 1
    • Under the screen, locate the black plastic strip that sits above the white plastic strip.
  6. Polaroid a520 LCD Screen Replacement: passo 6, immagine 1 di 1
    • Pull both sides of the black piece upward-about a mm.
    • The black plastic piece is not meant to come all the way off, just enough to release the screen.
    • Once the piece is lifted carefully slide the screen out of the slot.
Conclusione
Dani
Membro da: 06/24/10
21 Reputazione
7 Guide realizzate
Cal Poly, Team 3-3, Johann Summer 2010 Membro di Cal Poly, Team 3-3, Johann Summer 2010
CPSU-JOHANN-R10S3G3
2 Membri
7 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 10
Ultimi 30 Giorni: 14
Tutti i Tempi: 1,681
