Salta al contenuto principale
Polaroid Z2300 Battery Replacement
  1. Polaroid Z2300 Battery Replacement, Battery: passo 1, immagine 1 di 2 Polaroid Z2300 Battery Replacement, Battery: passo 1, immagine 2 di 2
    • Turn the camera upside down and gently use your thumb to pull the hatch forward and then upwards.
    • Once you lift the hatch up you will see the battery.
  2. Polaroid Z2300 Battery Replacement: passo 2, immagine 1 di 2 Polaroid Z2300 Battery Replacement: passo 2, immagine 2 di 2
    • Once you see the battery, you will see a tab saying 'pull' attached to the battery. gently pull on it until the battery is removed from the camera.
    • You can pull the battery easily afterwards.
  3. Polaroid Z2300 Battery Replacement: passo 3, immagine 1 di 1
    • Afterwards, you can easily reattach the battery back.
Conclusione
Jasem Almeeli
Membro da: 03/02/17
101 Reputazione
1 Guida realizzata
USF Tampa, Team S13-G1, Cagle Spring 2017 Membro di USF Tampa, Team S13-G1, Cagle Spring 2017
USFT-CAGLE-S17S13G1
4 Membri
2 Guide realizzate
Un commento
Do you know where to find a replacement battery? I’ve looked all over the internet.
Wendy Ralph - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 55
Tutti i Tempi: 3,782
