Salta al contenuto principale
Polaroid Sun 600 LMS Lens Replacement
Cosa ti serve
  1. Polaroid Sun 600 LMS Lens Replacement, Lens: passo 1, immagine 1 di 2 Polaroid Sun 600 LMS Lens Replacement, Lens: passo 1, immagine 2 di 2
    • Move film door slide on the left side of camera forward.
    • Pull film door open.
  2. Polaroid Sun 600 LMS Lens Replacement: passo 2, immagine 1 di 2 Polaroid Sun 600 LMS Lens Replacement: passo 2, immagine 2 di 2
    • Open the flash assembly by holding the sides of the top piece of the camera and pushing up gently until it snaps into place.
    • If your camera is old or dirty, it may take more force to open the flash assembly.
  3. Polaroid Sun 600 LMS Lens Replacement: passo 3, immagine 1 di 2 Polaroid Sun 600 LMS Lens Replacement: passo 3, immagine 2 di 2
    • Use a spudger on each side to separate the flash segment from the main body.
    • Be careful not to do this too hard because you may pull out the connecting wires.
  4. Polaroid Sun 600 LMS Lens Replacement: passo 4, immagine 1 di 2 Polaroid Sun 600 LMS Lens Replacement: passo 4, immagine 2 di 2
    • Use several plastic opening tools around the edges of the camera's body to separate it from the plastic frame.
  5. Polaroid Sun 600 LMS Lens Replacement: passo 5, immagine 1 di 2 Polaroid Sun 600 LMS Lens Replacement: passo 5, immagine 2 di 2
    • Place left hand on the gray section and right hand on the black section.
    • Pull the sections apart.
  6. Polaroid Sun 600 LMS Lens Replacement: passo 6, immagine 1 di 2 Polaroid Sun 600 LMS Lens Replacement: passo 6, immagine 2 di 2
    • Carefully remove the damaged lens from the interior of the camera.
    • Replace with a new lens.
Conclusione
Ian Hosek
Membro da: 01/20/10
357 Reputazione
1 Guida realizzata
Cal Poly, Team 3-18, Maness Winter 2010 Membro di Cal Poly, Team 3-18, Maness Winter 2010
CPSU-MANESS-W10S3G18
4 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 13
Ultimi 30 Giorni: 48
Tutti i Tempi: 10,569
