Salta al contenuto principale
Polaroid SNAP Paper Door Replacement
Cosa ti serve
  1. Polaroid SNAP Paper Door Replacement, Paper Door: passo 1, immagine 1 di 1
    • Open the paper door of the camera, then locate and remove the screws that are on the top and bottom edge of the inside of the camera.
    • Screw head: Phillips, Screw length: 3mm
  2. Polaroid SNAP Paper Door Replacement: passo 2, immagine 1 di 2 Polaroid SNAP Paper Door Replacement: passo 2, immagine 2 di 2
    • Push the rear face plate from the short side nearest the screws you just removed towards the other short side of the camera. It should slide forward and unlock the clips holding it in place.
  3. Polaroid SNAP Paper Door Replacement: passo 3, immagine 1 di 2 Polaroid SNAP Paper Door Replacement: passo 3, immagine 2 di 2
    • Turn rear face plate over.
  4. Polaroid SNAP Paper Door Replacement: passo 4, immagine 1 di 3 Polaroid SNAP Paper Door Replacement: passo 4, immagine 2 di 3 Polaroid SNAP Paper Door Replacement: passo 4, immagine 3 di 3
    • Maneuver the plastic paper door out of the sockets one at a time. Make sure to be gentle so the plastic does not snap. Also, make sure to keep track of the small springs.
Conclusione
USF Tampa, Team 7-3, Cheng Spring 2016 Membro di USF Tampa, Team 7-3, Cheng Spring 2016
USFT-CHENG-S16S7G3
4 Membri
18 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 43
Tutti i Tempi: 6,907
