Salta al contenuto principale
Polaroid S7 Digitizer Replacement
Cosa ti serve
  1. Polaroid S7 Digitizer Replacement, Remove the back: passo 1, immagine 1 di 2 Polaroid S7 Digitizer Replacement, Remove the back: passo 1, immagine 2 di 2
    • Insert the flat end of one of the plastic opening tools between the screen and the colored back cover. Gently pry apart the pieces.
    • Carefully separate the screen from the back, taking care not to rip the ribbons connecting them.
  2. Polaroid S7 Digitizer Replacement: passo 2, immagine 1 di 2 Polaroid S7 Digitizer Replacement: passo 2, immagine 2 di 2
    • Insert the plastic opening tool into the wedge and pry it open.
  3. Polaroid S7 Digitizer Replacement: passo 3, immagine 1 di 1
    • Open the latch and pull to remove the LCD.
  4. Polaroid S7 Digitizer Replacement, Digitizer: passo 4, immagine 1 di 1
    • After you remove the digitizer, open the latch and remove the screen.
  5. Polaroid S7 Digitizer Replacement: passo 5, immagine 1 di 1
    • To install the new screen, insert the digitizer into the new screen and latch them back in.
Conclusione
USF Tampa, Team 1-2, Blackwell Winter 2015 Membro di USF Tampa, Team 1-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 6
Tutti i Tempi: 179
