Salta al contenuto principale
Polaroid S7 Battery Replacement
Cosa ti serve
  1. Polaroid S7 Battery Replacement, Remove the back: passo 1, immagine 1 di 2 Polaroid S7 Battery Replacement, Remove the back: passo 1, immagine 2 di 2
    • Insert the flat end of a soft plastic opening tool between the screen and the back cover.
    • Pry the two pieces apart.
    • Take care not to rip the ribbons that connect the screen to the back cover.
  2. Polaroid S7 Battery Replacement: passo 2, immagine 1 di 1
    • Use a metal spudger to remove the orange sticker.
  3. Polaroid S7 Battery Replacement: passo 3, immagine 1 di 1
    • Use the screwdriver to remove the 2 x 4 mm Phillips #00 head screws from the blue board located on the lower-right corner of the battery.
  4. Polaroid S7 Battery Replacement: passo 4, immagine 1 di 2 Polaroid S7 Battery Replacement: passo 4, immagine 2 di 2
    • Use the metal spudger to remove the three pieces of clear tape adhering from the battery to the blue board.
    • Pry the battery up from the right side.
  5. Polaroid S7 Battery Replacement: passo 5, immagine 1 di 1
    • Remove the yellow plastic that covers the battery connector.
  6. Polaroid S7 Battery Replacement: passo 6, immagine 1 di 1
    • Use a soldering iron to remove the wires connected to the battery.
Conclusione
USF Tampa, Team 1-2, Blackwell Winter 2015 Membro di USF Tampa, Team 1-2, Blackwell Winter 2015
USFT-BLACKWELL-W15S1G2
4 Membri
6 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 3,225
