Salta al contenuto principale
Polaroid S10 Speaker Replacement
Cosa ti serve
  1. Polaroid S10 Speaker Replacement, Removing the backcover: passo 1, immagine 1 di 3 Polaroid S10 Speaker Replacement, Removing the backcover: passo 1, immagine 2 di 3 Polaroid S10 Speaker Replacement, Removing the backcover: passo 1, immagine 3 di 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Speaker Replacement, Speaker Assembly: passo 2, immagine 1 di 2 Polaroid S10 Speaker Replacement, Speaker Assembly: passo 2, immagine 2 di 2
    • Use a heavy-duty nylon spudger to remove the tape.
    • Unscrew the four 5 mm screws with the J000 screwdriver that connects the speakers.
  3. Polaroid S10 Speaker Replacement, Desoldering the Speakers: passo 3, immagine 1 di 2 Polaroid S10 Speaker Replacement, Desoldering the Speakers: passo 3, immagine 2 di 2
    • Carefully desolder the 4 connections of the speakers.
    • Do not touch the soldering iron to the motherboard or LCD screen.
Conclusione
James
Membro da: 03/16/15
367 Reputazione
3 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 14
Tutti i Tempi: 361
