Salta al contenuto principale
Polaroid S10 Battery Replacement
Cosa ti serve
  1. Polaroid S10 Battery Replacement, Removing the backcover: passo 1, immagine 1 di 3 Polaroid S10 Battery Replacement, Removing the backcover: passo 1, immagine 2 di 3 Polaroid S10 Battery Replacement, Removing the backcover: passo 1, immagine 3 di 3
    • Place an opening pick between the volume button and the back cover.
    • More than one pick may be needed, but avoid placing more than two picks in the same space.
    • Excessive force on the pick will break the volume button.
    • Carefully remove the back cover using the metal spudger.
    • It is normal to hear a snapping noise due to the plastic tabs on the back cover.
  2. Polaroid S10 Battery Replacement, Battery: passo 2, immagine 1 di 3 Polaroid S10 Battery Replacement, Battery: passo 2, immagine 2 di 3 Polaroid S10 Battery Replacement, Battery: passo 2, immagine 3 di 3
    • Use a spudger to carefully remove the tape nearest to the battery.
    • Use caution while removing tape. Too much force can damage the device.
    • Gently use the spudger to remove the battery out of place by wedging it out from the bottom.
    • Do not move the battery. Moving it could cause the cables to be ripped out.
  3. Polaroid S10 Battery Replacement, Battery Connection: passo 3, immagine 1 di 2 Polaroid S10 Battery Replacement, Battery Connection: passo 3, immagine 2 di 2
    • Carefully desolder the 2 wires that connect the battery to the motherboard.
    • Do not touch the soldering iron to the motherboard or the LCD screen.
Conclusione
Follow these instructions to reassemble your device.
James
Membro da: 03/16/15
367 Reputazione
3 Guide realizzate
Un commento
Can't open the %#*@ thing!!!!!!!!!!
tosaguys - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 16
Tutti i Tempi: 5,206
