Salta al contenuto principale
Polaroid PTAB7XC Power Button Replacement
Cosa ti serve
  1. Polaroid PTAB7XC Power Button Replacement, Power Button: passo 1, immagine 1 di 2 Polaroid PTAB7XC Power Button Replacement, Power Button: passo 1, immagine 2 di 2
    • Remove the two 7 mm screws on the top of the device using a J00 Phillips screwdriver by turning them counterclockwise.
    • If the screw heads have corroded or been stripped, it may be necessary to use a larger screwdriver head, such as the J0.
  2. Polaroid PTAB7XC Power Button Replacement: passo 2, immagine 1 di 2 Polaroid PTAB7XC Power Button Replacement: passo 2, immagine 2 di 2
    • Pry the seam between the screen and the case on all four sides with a large plastic opening tool until the plastic case comes off.
    • The plastic case is now free from the device.
    • The plastic power button may or may not fall out at this point. There is no problem if it does.
  3. Polaroid PTAB7XC Power Button Replacement: passo 3, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    • Use tweezers to push on the side of the black plastic power button that is outside of the device case until the button is as far in as possible.
    • Pull on the part of the broken power button that is exposed on the inside of the device case using tweezers until the button itself comes loose of the case.
    • The power button is now replaceable.
Conclusione
Altre 2 persone hanno completato questa guida.
0Commenti sulla guida
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 1,009
