Salta al contenuto principale
Polaroid PMID701i 10 Panel Replacement
Cosa ti serve
  1. Polaroid PMID701i 10 Panel Replacement, Panel: passo 1, immagine 1 di 2 Polaroid PMID701i 10 Panel Replacement, Panel: passo 1, immagine 2 di 2
    • Turn off and unplug the device before starting replacement.
    • Flip the device so that the screen faces down, with the back facing up.
    • The back panel attaches to the device with four 4.0mm long screws, one at each corner, indicated by the red circles in the picture.
    • Unscrew the four screws with a PH000 screwdriver.
  2. Polaroid PMID701i 10 Panel Replacement: passo 2, immagine 1 di 2 Polaroid PMID701i 10 Panel Replacement: passo 2, immagine 2 di 2
    • Flip the device over so that the screen faces up, and the back faces down.
    • Separate the front panel using the Opening Tool on a corner to create an opening.
    • Removing the frame for the first time may take a significant amount of force.
    • Run the tool along the seams of the device to open up all the sides.
  3. Polaroid PMID701i 10 Panel Replacement: passo 3, immagine 1 di 1
    • Removing the panel too quickly may damage the cable that attaches parts between the two panels.
    • Gently lift the top panel from the bottom panel.
  4. Polaroid PMID701i 10 Panel Replacement: passo 4, immagine 1 di 2 Polaroid PMID701i 10 Panel Replacement: passo 4, immagine 2 di 2
    • The flexible flat cables (FFC) attach to parts in the bottom panel with zero insertion force (ZIF) connectors.
    • Use the Opening tool to flip up the black retaining flap on the smaller connector.
    • Gently lift the cable, parallel to the panel, to detach it.
  5. Polaroid PMID701i 10 Panel Replacement: passo 5, immagine 1 di 2 Polaroid PMID701i 10 Panel Replacement: passo 5, immagine 2 di 2
    • Use the Opening tool to flip up the black retaining flap on the larger connector.
Conclusione
Amy Li
Membro da: 01/31/17
627 Reputazione
5 Guide realizzate
Baylor, Team 3-4, Whitney Spring 2017 Membro di Baylor, Team 3-4, Whitney Spring 2017
BU-WHITNEY-S17S3G4
3 Membri
10 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 4
Tutti i Tempi: 124
