Salta al contenuto principale
Polaroid P902 Charging Port Replacement
Cosa ti serve
  1. Polaroid P902 Charging Port Replacement, Charging Port: passo 1, immagine 1 di 1
    • Using the PH00 screwdriver, remove the two 4mm screws located on both the left and right sides of the charging port on the bottom of the tablet.
  2. Polaroid P902 Charging Port Replacement: passo 2, immagine 1 di 1
    • Using the plastic opening tool, insert it into the crease where the glass screen meets the housing of the rest of the tablet. Once inserted, keep inserted and run along the edges to separate the plastic clips from each other to dislodge the back plastic away from the glass and internal components.
  3. Polaroid P902 Charging Port Replacement: passo 3, immagine 1 di 1
    • Using the PH00 screwdriver, unscrew the four 4.4 mm screws that are anchoring the circuit board down to the rest of the tablet.
  4. Polaroid P902 Charging Port Replacement: passo 4, immagine 1 di 1
    • Using your fingernail, gently lift up the connectors on the two tabs that are holding the ribbons in place to the circuit board.
    • Be careful when pulling out or reconnecting the ribbons, since if the ribbon or connectors break, they are hard to fix.
  5. Polaroid P902 Charging Port Replacement: passo 5, immagine 1 di 3 Polaroid P902 Charging Port Replacement: passo 5, immagine 2 di 3 Polaroid P902 Charging Port Replacement: passo 5, immagine 3 di 3
    • Using a soldering iron, desolder the points circled on the picture until the solder has liquefied enough to be able to remove the wires from the circuit board.
    • When using the soldering iron, be careful not to cause damage to the motherboard.
  6. Polaroid P902 Charging Port Replacement: passo 6, immagine 1 di 2 Polaroid P902 Charging Port Replacement: passo 6, immagine 2 di 2
    • Place the tip of the soldering iron on the four points circled in the image long enough to liquefy the surrounding solder.
  7. Polaroid P902 Charging Port Replacement: passo 7, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Using tweezers, remove the charging port from the circuit board.
    • This should be done quickly as the solder will begin to solidify.
Conclusione
Trent Moskwinski
Membro da: 03/26/18
145 Reputazione
1 Guida realizzata
IUPUI, Team S2-G2, Harley Spring 2018 Membro di IUPUI, Team S2-G2, Harley Spring 2018
IUPUI-HARLEY-S18S2G2
3 Membri
4 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 9
Tutti i Tempi: 757
