Salta al contenuto principale
Polaroid One-Step 600 Lens Replacement
Cosa ti serve
  1. Polaroid One-Step 600 Lens Replacement, Lens: passo 1, immagine 1 di 3 Polaroid One-Step 600 Lens Replacement, Lens: passo 1, immagine 2 di 3 Polaroid One-Step 600 Lens Replacement, Lens: passo 1, immagine 3 di 3
    • Open the flash compartment of the camera so it makes a 30 degree angle with the horizontal.
  2. Polaroid One-Step 600 Lens Replacement: passo 2, immagine 1 di 3 Polaroid One-Step 600 Lens Replacement: passo 2, immagine 2 di 3 Polaroid One-Step 600 Lens Replacement: passo 2, immagine 3 di 3
    • Separate the flash section of the camera from the main body by unhooking the sides with the spudger.
    • BE CAREFUL NOT TO YANK THE TWO SECTIONS APART BECAUSE THE BAND WIRE STILL ATTACHES THEM!
  3. Polaroid One-Step 600 Lens Replacement: passo 3, immagine 1 di 3 Polaroid One-Step 600 Lens Replacement: passo 3, immagine 2 di 3 Polaroid One-Step 600 Lens Replacement: passo 3, immagine 3 di 3
    • Fully open the battery/ cartridge compartment by sliding the side tab toward you.
  4. Polaroid One-Step 600 Lens Replacement: passo 4, immagine 1 di 3 Polaroid One-Step 600 Lens Replacement: passo 4, immagine 2 di 3 Polaroid One-Step 600 Lens Replacement: passo 4, immagine 3 di 3
    • Insert spudger in between face of camera and sides where the four tabs are located.
    • BE CAREFUL! The button that is pressed to take a picture may pop out of the camera at this step.
  5. Polaroid One-Step 600 Lens Replacement: passo 5, immagine 1 di 2 Polaroid One-Step 600 Lens Replacement: passo 5, immagine 2 di 2
    • Once tabs are released, pull face of camera straight out.
  6. Polaroid One-Step 600 Lens Replacement: passo 6, immagine 1 di 1
    • Use spudger to twist the notch on the lens into the opening to remove it.
  7. Polaroid One-Step 600 Lens Replacement: passo 7, immagine 1 di 2 Polaroid One-Step 600 Lens Replacement: passo 7, immagine 2 di 2
    • Carefully use spudger to release lens, then lift lens out of camera with fingers.
    • CAUTION: LENS MAY POP OUT OF CAMERA; REMOVE CAREFULLY.
  8. Polaroid One-Step 600 Lens Replacement: passo 8, immagine 1 di 1
    Attrezzo utilizzato in questo passaggio:
    Microfiber Cleaning Cloths
    $3.99
    Compra
    • Clean old lens with a microfiber cloth or get a new lens to put back into the camera.
Conclusione
Altre 8 persone hanno completato questa guida.
Doug Jimenez
Membro da: 01/21/10
538 Reputazione
2 Guide realizzate
Cal Poly, Team 16-31, Maness Winter 2010 Membro di Cal Poly, Team 16-31, Maness Winter 2010
CPSU-MANESS-W10S16G31
4 Membri
6 Guide realizzate
Un commento
Hi, since you seem to know stuff about Polaroid cameras, I was wondering if you could help me figure out what is wrong with mine. I have a Polaroid Instant One-Step and whenever I take pictures, they never fully develop. They are a blue-ish hue and are never clear. Is this because of the lens do you think? Or something completely different?
Thanks
H.Rose - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 19
Ultimi 30 Giorni: 48
Tutti i Tempi: 16,138
