Salta al contenuto principale
Polaroid A10 Back Cover Replacement
Cosa ti serve
  1. Polaroid A10 Back Cover Replacement, Back Cover: passo 1, immagine 1 di 3 Polaroid A10 Back Cover Replacement, Back Cover: passo 1, immagine 2 di 3 Polaroid A10 Back Cover Replacement, Back Cover: passo 1, immagine 3 di 3
    • Begin by having the side with volume and power button face up towards you.
    • Insert a plastic opening tool between the display and the back cover.
    • Once you have one plastic opening tool in, you can insert another one. While holding one in place, slide the other along the gap to release the tabs.
    • It is easier to remove the back cover, if the display screen is faced down.
    • The tabs must be released from all four sides before removing the back cover.
Conclusione
UW Tacoma, Team 3-3, Rose Winter 2015 Membro di UW Tacoma, Team 3-3, Rose Winter 2015
UWT-ROSE-W15S3G3
4 Membri
12 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 3
Tutti i Tempi: 739
