Salta al contenuto principale
Polarizer Replacement for Tri-LCD Projectors
  1. Polarizer Replacement for Tri-LCD Projectors, Polarizers: passo 1, immagine 1 di 2 Polarizer Replacement for Tri-LCD Projectors, Polarizers: passo 1, immagine 2 di 2
    • First of all, there are five screw sizes you'll encounter in this guide. I'll refer to them as size 1-5 throughout this guide.
    • Far Left (size 1): These screws secure the mainboard. There is also one helping to secure the I/O plate.
    • 2nd from left (size 2): This screw secures a ground wire to the I/O plate.
    • 3rd from left (size 3): These screws are used exclusively on the I/O plate.
    • 4th from left (size 4): These screws hold the projector's outer case together.
    • 2nd picture (size 5): Two of these screws secure the yoke assembly.
  2. Polarizer Replacement for Tri-LCD Projectors: passo 2, immagine 1 di 1
    • Start by removing these two screws (size 4) underneath the lamp cover.
    • Removing the lamp is not necessary for this repair, but may make the job easier.
  3. Polarizer Replacement for Tri-LCD Projectors: passo 3, immagine 1 di 2 Polarizer Replacement for Tri-LCD Projectors: passo 3, immagine 2 di 2
    • Remove these 5 screws (size 3) followed by the panel they secure.
  4. Polarizer Replacement for Tri-LCD Projectors: passo 4, immagine 1 di 1
    • Remove these 8 screws (size 4) which secure the top cover
  5. Polarizer Replacement for Tri-LCD Projectors: passo 5, immagine 1 di 1
    • Open the air filter cover, otherwise it will prevent the top cover from being opened
  6. Polarizer Replacement for Tri-LCD Projectors, Remove the Main Cover: passo 6, immagine 1 di 1
    • Place the projector right-side up and lift off the cover. Be sure to remove this ribbon cable.
  7. Polarizer Replacement for Tri-LCD Projectors: passo 7, immagine 1 di 1
    • Remove all 4 size 1 screws in RED.
    • Depending on your specific model of projector, you may also need to remove the black trim piece underneath the screw in the bottom right corner.
    • Do not remove the screw inside the BLUE circle. Doing so will cause a metal brace to fall into the projector which is difficult to reinstall.
  8. Polarizer Replacement for Tri-LCD Projectors: passo 8, immagine 1 di 1
    • Unplug all of these connectors.
    • Note that one on the top left corner is on the bottom of the board
    • Although the metal shield is removed in this picture, you do not need to remove it
    • Removing these connectors will allow you to flip the board up and out of the way. If you want to remove it completely, unplug all the connectors
    • Don't worry much about not being able to remember where each cable goes, most of them use different connectors to make it impossible to mess up
  9. Polarizer Replacement for Tri-LCD Projectors: passo 9, immagine 1 di 1
    • Remove this screw (size 3).
  10. Polarizer Replacement for Tri-LCD Projectors: passo 10, immagine 1 di 1
    • Remove the left screw (size 1)
    • Remove the right screw (size 2)
  11. Polarizer Replacement for Tri-LCD Projectors, Remove the Mainboard: passo 11, immagine 1 di 1
    • Carefully flip the mainboard up to the right.
    • The board WILL catch on the bottom left corner, so be careful.
    • Side note: another common problem is having one of the mirrors fall out of place due to heat. It may be a good idea at this step to remove the cover of the mirror housing and check for this problem. If one of them has fallen off, use two-part epoxy to put it back in place, making sure to keep it pressed firmly and evenly against its seat.
  12. Polarizer Replacement for Tri-LCD Projectors, Remove the Polarizer: passo 12, immagine 1 di 1
    • This is the green polarizer
    • Remove the screw and pull it out
  13. Polarizer Replacement for Tri-LCD Projectors: passo 13, immagine 1 di 1
    • This is a burned polarizer.
    • If yours looks like this, you've found your problem.
  14. Polarizer Replacement for Tri-LCD Projectors: passo 14, immagine 1 di 1
    • This is what a good polarizer should look like.
    • You'll need to source a new one, which can be tricky. Lots of Epson projectors use the same polarizer though, so you may be able to pull one from a different projector.
  15. Polarizer Replacement for Tri-LCD Projectors: passo 15, immagine 1 di 1
    • Once you have a new polarizer, install it and the mainboard in order to test the projector. There is a kill switch for the lamp door you will need to hold down in order to power on the projector while it is disassembled.
    • If the level of green looks good, you are finished and can proceed with reassembly
    • If the level of green looks off, proceed to step 16
  16. Polarizer Replacement for Tri-LCD Projectors: passo 16, immagine 1 di 1
    • As you can see, the screw doubles as an adjustment point, which you may have to adjust to get a good green level.
    • Cut through the glue and slide the polarizer left or right until the projector's color looks good. This can be a bit tedious because you need to reinstall the mainboard to test it between each adjustment.
    • Sliding to the left will increase the amount of green let through.
    • Sliding to the right will decrease it.
    • Once you get it adjusted how you want, you're done! Just reassemble the projector and you're good to go.
Conclusione
Altre 6 persone hanno completato questa guida.
7Commenti sulla guida
Where did you order the polarizers from?
fl sf - Replica
hola tengo un epson 395W me hace una mancha roja por un lado y el lado contrario una azul que cubre el lateral y la parte superior los puedo reemplazar por otros de misma serie powerlite sin importar que no tengan la misma nomenclatura ejemplo H395R el mio y este de la imagen aqui de ejemplo es H372R unicamente tienen que ser de el tamaño y color igual ? Gracias
Ernesto Bucio - Replica
Your issue sounds more like a mirror that has fallen off. I'd recommend disassembling through step 11, removing the cover of the mirror housing (large black "U" shaped piece) and checking if there is a loose mirror. If there is, two part epoxy can be used to glue it back in place. If you do need a new polarizer, they are compatible across most Epson models, but I don't know specifically which ones. If it looks visually similar, it should fit.
Su problema suena más como un espejo que se ha caído. Recomendaría desarmar hasta el paso 11, quitar la cubierta de la carcasa del espejo (pieza grande negra en forma de "U") y verificar si hay un espejo suelto. Si es así, se puede utilizar epoxi de dos componentes para volver a pegarlo en su lugar. Si necesita un polarizador nuevo, son compatibles con la mayoría de los modelos Epson, pero no sé específicamente cuáles. Si se ve visualmente similar, debería encajar.
Timothy Fryer -
I have a Epson 535W that I bought used and I have a thin red line on the right hand edge of the projection. I have tried everything in the settings to get rid of it, after reading over your steps about the polarizer removal , I think it might be that one of the mirrors might have moved. Would the line be cause by the mirror or a defective polarizer? Thanks for this article it is great.
TBS99 - Replica
In my experience, a defective polarizing filter will discolor the entire image, so probably no issue there. Here's a couple of things to check; first, is there a corresponding greenish line on the left side of the screen? And looking closely at the screen, does the R,G, or B element of each pixel not quite line up? If so, one of your LCDs is misaligned. You could try reseating whichever LCD corresponds the the misaligned color, but I haven't had much luck fixing this problem so I don't have much advice to offer here. I'll re-add a section to this guide to aid in disassembling this section. Second, pick the projector up and rotate it around a bit while it's running. Does the red area change at all? If so, your issue is definitely a loose mirror, which should be a much easier fix. Hope this helps!
Timothy Fryer -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 68
Ultimi 30 Giorni: 295
Tutti i Tempi: 7,957
