Salta al contenuto principale
Polar V800 Charging Port Cover Replacement
Cosa ti serve
  1. Polar V800 Charging Port Cover Replacement, Watch Band: passo 1, immagine 1 di 3 Polar V800 Charging Port Cover Replacement, Watch Band: passo 1, immagine 2 di 3 Polar V800 Charging Port Cover Replacement, Watch Band: passo 1, immagine 3 di 3
    • Using a narrow object like a paperclip, push the pins located in the watch band in the direction of the arrow indicated on the watch.
    • Completely pull out the pins.
    • It isn't necessary to remove the watch band before replacing other parts of the watch, but it may make removal of other elements of the watch more accessible and clear.
    • When replacing the charging port cover, only take out the pin that is closest to the charging port cover.
  2. Polar V800 Charging Port Cover Replacement: passo 2, immagine 1 di 3 Polar V800 Charging Port Cover Replacement: passo 2, immagine 2 di 3 Polar V800 Charging Port Cover Replacement: passo 2, immagine 3 di 3
    • To remove the watch band, pull each end of the watch band away from the watch frame.
  3. Polar V800 Charging Port Cover Replacement, Charging Port Cover: passo 3, immagine 1 di 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: passo 3, immagine 2 di 3 Polar V800 Charging Port Cover Replacement, Charging Port Cover: passo 3, immagine 3 di 3
    • Take off the charging port cover.
Conclusione
Nick B.
Membro da: 04/29/18
392 Reputazione
1 Guida realizzata
Cal Poly, Team S17-G6, Livingston Spring 2018 Membro di Cal Poly, Team S17-G6, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G6
4 Membri
8 Guide realizzate
1Commento della guida
where does not procure the battery port cover ?
Chenthill P - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 5
Ultimi 30 Giorni: 23
Tutti i Tempi: 3,175
