Salta al contenuto principale
Polar M400 Watch Battery Replacement
Cosa ti serve
  1. Polar M400 Watch Battery Replacement, Wrist Strap: passo 1, immagine 1 di 1
    • Insert a standard paper clip into the holes on both sides of the watch that connect the watch's face with the wrist strap.
  2. Polar M400 Watch Battery Replacement: passo 2, immagine 1 di 2 Polar M400 Watch Battery Replacement: passo 2, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Apply an upward pressure to the holes until the locking pins release.
    • Use precision tweezers to remove the pins that connect the face with the strap.
  3. Polar M400 Watch Battery Replacement: passo 3, immagine 1 di 1
    • Once the pins are released, the old wrist strap should snap off.
    • Simply lock the new wrist strap into place.
  4. Polar M400 Watch Battery Replacement, Battery: passo 4, immagine 1 di 1
    • Use the T5 head on the iFixit screwdriver to unscrew the four screws on the back of the watch’s face.
  5. Polar M400 Watch Battery Replacement: passo 5, immagine 1 di 2 Polar M400 Watch Battery Replacement: passo 5, immagine 2 di 2
    • Gently remove the backing from the watch.
  6. Polar M400 Watch Battery Replacement: passo 6, immagine 1 di 2 Polar M400 Watch Battery Replacement: passo 6, immagine 2 di 2
    Compra
    • Use tweezers to gently pry the golden sensor away from the battery.
    • Remove battery using the plastic opening tools.
Conclusione
Altre 15 persone hanno completato questa guida.
25 Commenti
Hello, thanks for the details !
The most tricky part: find the right spare part. I can’t find a replacement battery that could fit the original dimensions with reasonnable capacity.
Do you have any lead?
Vincent - Replica
In case if anyone is still looking for the spare part I have just replaced my M400 battery with this one: https://www.aliexpress.com/item/10050045...
Replacement instructions were detailed enough to get my watch to work again.
Roman -
Bonjour
Pourriez-vous m’indiquer ou je peux acheter une batterie compatible ou originale
Merci à vous
ducellier - Replica
where can i buy a batery for my polar m400? Link please. Thanks
lsmi_21 - Replica
Once the battery is changed, the M400 does not work. Do you have to press any combination of keys?
lojobis - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 7
Ultimi 7 Giorni: 45
Ultimi 30 Giorni: 202
Tutti i Tempi: 30,144
