Salta al contenuto principale
Poin2 Chromebook 11 Speaker Replacement
Cosa ti serve
  1. Poin2 Chromebook 11 Speaker Replacement, Battery: passo 1, immagine 1 di 2 Poin2 Chromebook 11 Speaker Replacement, Battery: passo 1, immagine 2 di 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Speaker Replacement: passo 2, immagine 1 di 3 Poin2 Chromebook 11 Speaker Replacement: passo 2, immagine 2 di 3 Poin2 Chromebook 11 Speaker Replacement: passo 2, immagine 3 di 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Speaker Replacement: passo 3, immagine 1 di 3 Poin2 Chromebook 11 Speaker Replacement: passo 3, immagine 2 di 3 Poin2 Chromebook 11 Speaker Replacement: passo 3, immagine 3 di 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Speaker Replacement: passo 4, immagine 1 di 2 Poin2 Chromebook 11 Speaker Replacement: passo 4, immagine 2 di 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Speaker Replacement: passo 5, immagine 1 di 1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Speaker Replacement, Speakers: passo 6, immagine 1 di 2 Poin2 Chromebook 11 Speaker Replacement, Speakers: passo 6, immagine 2 di 2
    • Unplug the black speaker cable from the lower, left side of the motherboard.
  7. Poin2 Chromebook 11 Speaker Replacement: passo 7, immagine 1 di 3 Poin2 Chromebook 11 Speaker Replacement: passo 7, immagine 2 di 3 Poin2 Chromebook 11 Speaker Replacement: passo 7, immagine 3 di 3
    • Use the opening tool to pry the two speakers away from the frame.
    • An adhesive strip attaches each speaker to the frame. The speakers should pull away with moderate force.
  8. Poin2 Chromebook 11 Speaker Replacement: passo 8, immagine 1 di 2 Poin2 Chromebook 11 Speaker Replacement: passo 8, immagine 2 di 2
    • Detach the speaker cord from the hooks holding it to the frame and lift the speakers away.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 2
Ultimi 7 Giorni: 6
Ultimi 30 Giorni: 7
Tutti i Tempi: 211
