Salta al contenuto principale
Poin2 Chromebook 11 Charging Port Replacement
Cosa ti serve
  1. Poin2 Chromebook 11 Charging Port Replacement, Battery: passo 1, immagine 1 di 2 Poin2 Chromebook 11 Charging Port Replacement, Battery: passo 1, immagine 2 di 2
    • Power down the Poin2 Chromebook 11 and disconnect the power adapter.
    • Close the Chromebook and position it with the base facing up.
    • Use a #0 Phillips screwdriver to unscrew the ten 7mm screws that hold the base to the rest of the frame
    • Poin2 Chromebook 11 does not have screws under its rubber feet at the base.
  2. Poin2 Chromebook 11 Charging Port Replacement: passo 2, immagine 1 di 3 Poin2 Chromebook 11 Charging Port Replacement: passo 2, immagine 2 di 3 Poin2 Chromebook 11 Charging Port Replacement: passo 2, immagine 3 di 3
    • Insert a 1cm-wide plastic opening tool between the base and top frame.
    • Applying pressure up and down with the tool may be necessary. When you hear a "click," this indicates the separation of the frame.
    • Pry (up and down) around the entire border of the Chromebook to separate.
    • Use your hands to gently lift the base away from the frame.
  3. Poin2 Chromebook 11 Charging Port Replacement: passo 3, immagine 1 di 3 Poin2 Chromebook 11 Charging Port Replacement: passo 3, immagine 2 di 3 Poin2 Chromebook 11 Charging Port Replacement: passo 3, immagine 3 di 3
    • Disconnect the white 8-wire battery connector from the motherboard using a spudger to push the two L-shaped clips out of the port.
    • The connector is a tight fit and requires careful pressure for release.
  4. Poin2 Chromebook 11 Charging Port Replacement: passo 4, immagine 1 di 2 Poin2 Chromebook 11 Charging Port Replacement: passo 4, immagine 2 di 2
    • Remove the six 4mm screws using a Phillips #0 screwdriver.
  5. Poin2 Chromebook 11 Charging Port Replacement: passo 5, immagine 1 di 1
    • Lift the battery from the frame.
  6. Poin2 Chromebook 11 Charging Port Replacement, Charging Port: passo 6, immagine 1 di 2 Poin2 Chromebook 11 Charging Port Replacement, Charging Port: passo 6, immagine 2 di 2
    • The changing port is located on the upper-right corner of the computer.
    • Disconnect the charging port from the motherboard using a spudger to push the 4-wire connector out from the port.
  7. Poin2 Chromebook 11 Charging Port Replacement: passo 7, immagine 1 di 2 Poin2 Chromebook 11 Charging Port Replacement: passo 7, immagine 2 di 2
    • Remove silver tape covering hinge.
  8. Poin2 Chromebook 11 Charging Port Replacement: passo 8, immagine 1 di 2 Poin2 Chromebook 11 Charging Port Replacement: passo 8, immagine 2 di 2
    • The metal hinge at the top right corner must be lifted to access the charging port.
    • Use a Phillips #0 screwdriver and remove the two 7mm screws from the hinge.
  9. Poin2 Chromebook 11 Charging Port Replacement: passo 9, immagine 1 di 1
    • Pry the metal hinge up, until it sits perpendicular to the motherboard.
    • The metal hinge is a tight fit and requires careful strength when lifting.
  10. Poin2 Chromebook 11 Charging Port Replacement: passo 10, immagine 1 di 2 Poin2 Chromebook 11 Charging Port Replacement: passo 10, immagine 2 di 2
    Attrezzo utilizzato in questo passaggio:
    Compra
    • Use tweezers to gently pull the charging port out of the frame.
Conclusione
Altre 4 persone hanno completato questa guida.
2 Commenti
Great, Now where can I find this part to fix my laptop???
marrowii - Replica
where do I buy the new port???
rhena9 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 49
Ultimi 30 Giorni: 170
Tutti i Tempi: 7,250
