Introduzione
If your Nerf Blaster latches and releases when you pull the trigger, but doesn't fire the dart, the O-ring might be ripped and need replacing. This guide will show you how to disassemble your Nite Finder so that you can replace the O-ring and the plunger.
==Caution==
Be aware of springs under compression. Take care so these small parts do not fly off the blaster and get lost.
Cosa ti serve
Place the blaster upside down on the table, and remove the screw in the bottom of the handle
Remove the battery door and take the batteries out.
