Introduzione
This guide will show you how to safely replace a speaker on you Plum Optimax 10 tablet.
NOTE: If following this guide, it is only necessary to clip and solder the wires from one side of the speaker wires. If your replacement speaker has a long lead wire, clip the wire from the motherboard connection and solder there, while if your replacement speaker has no lead wires you should only clip and solder the connections at the speaker end.
Cosa ti serve
Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
Use flathead screwdriver tool to remove the three 2.5 mm screws shown in the photo. Two screws are located at the base of the motherboard and there is one screw located at the top.
On the top side of the motherboard (where the black and red wires are), locate and look closely for the "SPK1" lead.
Use a pair of wire cutters to clip the wires from the "SPK1" lead.
The speaker will pop out of its place and use the wire cutters to remove the wires connected from "SPK1" from the speaker.
