Introduzione
Please follow each step closely and if you are having trouble, go back a step and see where your issue is. May this guide be in your favor!
Cosa ti serve
Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
Disconnect the ribbon cable connecting the headphone jack on the motherboard by lifting up on the black press fit connector with a plastic opening tool.
Use a plastic opening tool to pry up the headphone jack from its place in the case.
