Salta al contenuto principale
Plum Optimax 10 Headphone Jack Replacement
Cosa ti serve
  1. Plum Optimax 10 Headphone Jack  Replacement, Back Cover: passo 1, immagine 1 di 2 Plum Optimax 10 Headphone Jack  Replacement, Back Cover: passo 1, immagine 2 di 2
    • Use a metal spudger to remove the small panels to the immediate left and right side of the camera.
  2. Plum Optimax 10 Headphone Jack  Replacement: passo 2, immagine 1 di 2 Plum Optimax 10 Headphone Jack  Replacement: passo 2, immagine 2 di 2
    • Use a metal spudger to begin lifting the back cover.
    • Then, create leverage and gently remove the entire cover.
  3. Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: passo 3, immagine 1 di 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: passo 3, immagine 2 di 3 Plum Optimax 10 Headphone Jack  Replacement, Headphone Jack: passo 3, immagine 3 di 3
    • Disconnect the ribbon cable connecting the headphone jack on the motherboard by lifting up on the black press fit connector with a plastic opening tool.
    • Use a plastic opening tool to pry up the headphone jack from its place in the case.
    • The headphone jack is lightly adhered to the back case.
    • When removing the jack, be gentle with the ribbon wire because it is capable of tearing.
Conclusione
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 2
Ultimi 30 Giorni: 6
Tutti i Tempi: 82
