Salta al contenuto principale
Plugging in Shure SM58 XLR Cable
  1. Plugging in Shure SM58 XLR Cable, XLR Cable Plug In: passo 1, immagine 1 di 1
    • Make sure you have a proper three pin XLR cable.
    • Grab the female end of the cable (plug with three holes).
  2. Plugging in Shure SM58 XLR Cable: passo 2, immagine 1 di 1
    • Line up the pins in the end of the microphone (microphone connecter) with the holes in the XLR cable.
  3. Plugging in Shure SM58 XLR Cable: passo 3, immagine 1 di 1
    • Once the pins are aligned, push the cable into the bottom end of the microphone. You should hear a click.
Conclusione
To disconnect the cable from the microphone, follow the instructions in reverse.
Altre 13 persone hanno completato questa guida.
nat coll
Membro da: 09/27/12
642 Reputazione
14 Guide realizzate
Cal Poly, Team 7-53, Forte Fall 2012 Membro di Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membri
20 Guide realizzate
21 Commenti
When disconnecting the cable - press the little latch (pointing towards you in the last picture) to release and then pull the cable out.
harrywwc - Replica
Is this April's fool? XD
s6963172 - Replica
how i repair the PG48 the XLR conector moves in and out when the cable ar plugged. The conector male in the microphone have an screw but that one not works...
What am i do?
If you have an idea to the answer or any tip to resolve this trouble feel fre to tweet me.
@ Theradioholic
on
#Twitter
Santiago Morales - Replica
I know a few people who would see this and still screw it up.
jimboc - Replica
do it in reverse? you have to press the button though on the male end...
Michael Fox - Replica
Will this work with an Audio-Technica ATM-410, or just the Shure?
cbrislain - Replica
Just Shure. On Audio-Technica you have to rotate the plug six times clockwise and whisper a few nice words into it before plugging it in. I've always found that lullabies work quite well.
staale -
I have a 1/4 adapter on my Shure, is that process different? I can't seem to make the male 1/4" connect to the female XLR
JON CAMPBELL - Replica
Push harder.
staale -
Some of us are musicians , so we appreciate the help
tomandlindafirme - Replica
When do you hear the sound from it?
Charlie Green - Replica
Bloomin' eck.... & I've been using cellotape, Blu Tak and super glue. No wonder I had to revert to the megaphone all the time
george sandoz - Replica
I don't know about you lando77 but I always blow on the female end (the cable end with the holes) to blow dry any moisture out. What good does it do to blow on the male pins?
darryltrimm - Replica
Do these instructions work for the ElectroVoice EV 635A as well?
carterjim - Replica
This is useless. Why didn't you post a video that shows the process.
mperloe - Replica
Wow!!! Thank you so much! This is really great information. Now I won't have to hire people to come do this for me anymore. Can you post a video of how to put the microphone on a stand?
dhoffman98 - Replica
Thanks for posting this, I recently ran out of toilet tissue and have been using my Shure SM58 Owner's Manual. You're a lifesaver!
hemightbefluffy - Replica
He's holding the plug with his right hand. But what if I'm left handed. Do I need to rotate it? Or should I switch what side I'm standing on?
Bob DeMaa - Replica
Managed it on 5th attempt , now what the heck do I do with the other end of the cable ???
gary blair - Replica
are these instructions specifically for drummers or can anybody use them?
Cedric the Dead - Replica
Hola ..he comprado un micrófono shure pg48 1i no se porque al conectar con el cable no se escucha ningun sonido..
cristianbocanel51 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 38
Ultimi 30 Giorni: 126
Tutti i Tempi: 67,378
