Salta al contenuto principale
Plugging in Shure SM58 XLR Cable
  1. Plugging in Shure SM58 XLR Cable, XLR Cable Plug In: passo 1, immagine 1 di 1
    • Make sure you have a proper three pin XLR cable.
    • Grab the female end of the cable (plug with three holes).
  2. Plugging in Shure SM58 XLR Cable: passo 2, immagine 1 di 1
    • Line up the pins in the end of the microphone (microphone connecter) with the holes in the XLR cable.
  3. Plugging in Shure SM58 XLR Cable: passo 3, immagine 1 di 1
    • Once the pins are aligned, push the cable into the bottom end of the microphone. You should hear a click.
Conclusione
To disconnect the cable from the microphone, follow the instructions in reverse.
Altre 13 persone hanno completato questa guida.
nat coll
Membro da: 09/27/12
670 Reputazione
14 Guide realizzate
Cal Poly, Team 7-53, Forte Fall 2012 Membro di Cal Poly, Team 7-53, Forte Fall 2012
CPSU-FORTE-F12S7G53
5 Membri
20 Guide realizzate
21 Commenti
When disconnecting the cable - press the little latch (pointing towards you in the last picture) to release and then pull the cable out.
harrywwc - Replica
Is this April's fool? XD
s6963172 - Replica
how i repair the PG48 the XLR conector moves in and out when the cable ar plugged. The conector male in the microphone have an screw but that one not works...
What am i do?
If you have an idea to the answer or any tip to resolve this trouble feel fre to tweet me.
@ Theradioholic
on
#Twitter
Santiago Morales - Replica
I know a few people who would see this and still screw it up.
jimboc - Replica
do it in reverse? you have to press the button though on the male end...
Michael Fox - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 25
Ultimi 30 Giorni: 115
Tutti i Tempi: 67,800
