Salta al contenuto principale
Playstation Classic Power Button Replacement
Cosa ti serve
  1. Playstation Classic Power Button Replacement, Motherboard: passo 1, immagine 1 di 1
    • Flip the console so its back is facing up.
  2. Playstation Classic Power Button Replacement: passo 2, immagine 1 di 1
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. Playstation Classic Power Button Replacement: passo 3, immagine 1 di 3 Playstation Classic Power Button Replacement: passo 3, immagine 2 di 3 Playstation Classic Power Button Replacement: passo 3, immagine 3 di 3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. Playstation Classic Power Button Replacement: passo 4, immagine 1 di 1
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. Playstation Classic Power Button Replacement: passo 5, immagine 1 di 3 Playstation Classic Power Button Replacement: passo 5, immagine 2 di 3 Playstation Classic Power Button Replacement: passo 5, immagine 3 di 3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. Playstation Classic Power Button Replacement: passo 6, immagine 1 di 3 Playstation Classic Power Button Replacement: passo 6, immagine 2 di 3 Playstation Classic Power Button Replacement: passo 6, immagine 3 di 3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. Playstation Classic Power Button Replacement, Power Button: passo 7, immagine 1 di 3 Playstation Classic Power Button Replacement, Power Button: passo 7, immagine 2 di 3 Playstation Classic Power Button Replacement, Power Button: passo 7, immagine 3 di 3
    • After removing the motherboard, position the casing so that the back of the power button is visible.
    • Use a spudger to apply pressure inward on the three plastic clips.
    • This will loosen the button enough to remove it from its position.
  8. Playstation Classic Power Button Replacement: passo 8, immagine 1 di 3 Playstation Classic Power Button Replacement: passo 8, immagine 2 di 3 Playstation Classic Power Button Replacement: passo 8, immagine 3 di 3
    • Flip the casing to its front and remove the loose button with your hand.
    • Leave the spring in its original position.
Conclusione
To reassemble your device, follow these instructions in reverse order.
Maxwell Webb
Membro da: 04/22/19
631 Reputazione
5 Guide realizzate
Cal Poly, Team S2-G8, Maness Spring 2019 Membro di Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
2 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 7
Ultimi 30 Giorni: 39
Tutti i Tempi: 2,526
