Salta al contenuto principale
Playstation 3 Power Supply Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Playstation 3 Power Supply Replacement, Top Cover: passo 1, immagine 1 di 2 Playstation 3 Power Supply Replacement, Top Cover: passo 1, immagine 2 di 2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Power Supply Replacement: passo 2, immagine 1 di 1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Power Supply Replacement: passo 3, immagine 1 di 2 Playstation 3 Power Supply Replacement: passo 3, immagine 2 di 2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Power Supply Replacement: passo 4, immagine 1 di 2 Playstation 3 Power Supply Replacement: passo 4, immagine 2 di 2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Power Supply Replacement: passo 5, immagine 1 di 3 Playstation 3 Power Supply Replacement: passo 5, immagine 2 di 3 Playstation 3 Power Supply Replacement: passo 5, immagine 3 di 3
    • You can now lift off the top cover.
  6. Playstation 3 Power Supply Replacement, Power Supply: passo 6, immagine 1 di 2 Playstation 3 Power Supply Replacement, Power Supply: passo 6, immagine 2 di 2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Power Supply Replacement: passo 7, immagine 1 di 1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Power Supply Replacement: passo 8, immagine 1 di 2 Playstation 3 Power Supply Replacement: passo 8, immagine 2 di 2
    • Remove the power supply by lifting it straight up.
Conclusione
Altre 2 persone hanno completato questa guida.
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 3
Ultimi 30 Giorni: 8
Tutti i Tempi: 1,487
