Salta al contenuto principale
Playstation 3 Fan Replacement
Guida Archiviata
Questa guida è mantenuta solo per scopi storici. Usa la versione aggiornata della guida per eseguire la riparazione.
Cosa ti serve
  1. Playstation 3 Fan Replacement, Top Cover: passo 1, immagine 1 di 2 Playstation 3 Fan Replacement, Top Cover: passo 1, immagine 2 di 2
    • Remove the rubber screw cover near the hard drive cover with a spudger.
  2. Playstation 3 Fan Replacement: passo 2, immagine 1 di 1
    • Remove the screw holding the top cover in place with a Torx T10 screwdriver.
  3. Playstation 3 Fan Replacement: passo 3, immagine 1 di 2 Playstation 3 Fan Replacement: passo 3, immagine 2 di 2
    • Slide the top cover down about half an inch.
    • Lift the cover off of the PS3.
  4. Playstation 3 Fan Replacement: passo 4, immagine 1 di 2 Playstation 3 Fan Replacement: passo 4, immagine 2 di 2
    • Remove the seven screws in the top cover with a Phillips #2 screwdriver.
    • One of the screws is shorter than the others. The short screw is marked in yellow.
  5. Playstation 3 Fan Replacement: passo 5, immagine 1 di 3 Playstation 3 Fan Replacement: passo 5, immagine 2 di 3 Playstation 3 Fan Replacement: passo 5, immagine 3 di 3
    • You can now lift off the top cover.
  6. Playstation 3 Fan Replacement, Power Supply: passo 6, immagine 1 di 2 Playstation 3 Fan Replacement, Power Supply: passo 6, immagine 2 di 2
    • Unplug the white wires connected to the wireless board. There are two sets of wires: one set in the front, one in the back.
    • Push down the tab on the connector to disconnect the wires.
    • Remove the two screws on the front of the power supply.
  7. Playstation 3 Fan Replacement: passo 7, immagine 1 di 1
    • Remove the screws on the back of the power supply with a Phillips #2 screwdriver.
  8. Playstation 3 Fan Replacement: passo 8, immagine 1 di 2 Playstation 3 Fan Replacement: passo 8, immagine 2 di 2
    • Remove the power supply by lifting it straight up.
  9. Playstation 3 Fan Replacement, Motherboard Enclosure: passo 9, immagine 1 di 2 Playstation 3 Fan Replacement, Motherboard Enclosure: passo 9, immagine 2 di 2
    • Unplug the optical drive power cable.
    • Detach the ribbon cable that connects the optical drive to the motherboard.
    • Set the optical drive aside.
  10. Playstation 3 Fan Replacement: passo 10, immagine 1 di 2 Playstation 3 Fan Replacement: passo 10, immagine 2 di 2
    • Remove three screws (Phillips #2) from the wireless board and antenna.
    • Detach the ribbon cable that connects the wireless board to the motherboard.
  11. Playstation 3 Fan Replacement: passo 11, immagine 1 di 1
    • Remove nine screws (Phillips #2) from the perimeter of the metal plate covering the motherboard.
  12. Playstation 3 Fan Replacement: passo 12, immagine 1 di 3 Playstation 3 Fan Replacement: passo 12, immagine 2 di 3 Playstation 3 Fan Replacement: passo 12, immagine 3 di 3
    • Remove the hard drive door with a spudger.
    • Lift the metal enclosure out of the plastic bottom case.
  13. Playstation 3 Fan Replacement, Fan: passo 13, immagine 1 di 1
    • Remove the three screws (Phillips #2).
    • Disconnect the fan's power cable.
    • Lift the fan straight up and out.
Conclusione
iDeleted
Membro da: 07/07/10
2.101 Reputazione
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 0
Ultimi 30 Giorni: 0
Tutti i Tempi: 2,790
