Salta al contenuto principale
PlayStation Vita Wi-Fi Antenna Replacement
Cosa ti serve
  1. PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: passo 1, immagine 1 di 2 PlayStation Vita Wi-Fi Antenna Replacement, Case Separation: passo 1, immagine 2 di 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Wi-Fi Antenna Replacement: passo 2, immagine 1 di 3 PlayStation Vita Wi-Fi Antenna Replacement: passo 2, immagine 2 di 3 PlayStation Vita Wi-Fi Antenna Replacement: passo 2, immagine 3 di 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Wi-Fi Antenna Replacement: passo 3, immagine 1 di 2 PlayStation Vita Wi-Fi Antenna Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Wi-Fi Antenna Replacement: passo 4, immagine 1 di 3 PlayStation Vita Wi-Fi Antenna Replacement: passo 4, immagine 2 di 3 PlayStation Vita Wi-Fi Antenna Replacement: passo 4, immagine 3 di 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Wi-Fi Antenna Replacement: passo 5, immagine 1 di 2 PlayStation Vita Wi-Fi Antenna Replacement: passo 5, immagine 2 di 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Wi-Fi Antenna Replacement: passo 6, immagine 1 di 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Wi-Fi Antenna Replacement: passo 7, immagine 1 di 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Wi-Fi Antenna Replacement: passo 8, immagine 1 di 1
    • Separate the front and rear cases.
  9. PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 9, immagine 1 di 2 PlayStation Vita Wi-Fi Antenna Replacement, Wi-Fi Antenna: passo 9, immagine 2 di 2
    • Using the pointy end of a spudger, gently pry the white Wi-Fi antenna cable connecotr off of the wireless card.
    • Deroute the Wi-Fi antenna cable out of the black plastic casing.
  10. PlayStation Vita Wi-Fi Antenna Replacement: passo 10, immagine 1 di 2 PlayStation Vita Wi-Fi Antenna Replacement: passo 10, immagine 2 di 2
    • Using the pointy end of the spudger, gently pry the Wi-Fi antenna cable connector off of the left button board at the connection.
    • Remove the Wi-Fi antenna cable.
Conclusione
Brittany McCrigler
Membro da: 03/05/12
88.901 Reputazione
131 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.476 Guide realizzate
4 Commenti
what about the ps vita slim 2000 model? ive got no wifi at all but cant see a teardown to find the wifi module
Keegan - Replica
Is WiFi / 3G antenna cable: UFL/IPEX to UFL/IPEX 1.3mm? What is the white cable length?
samohvalov2010 - Replica
Yeah this is not a Wifi antenna cable. The "wireless card" only does 3G and GPS/Glonass. Wifi controller is on the mainboard itself.
computer1up - Replica
^ okay that explains a lot, i thought i was missing parts in my PSV1000 wifi
Bronson - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 12
Ultimi 30 Giorni: 64
Tutti i Tempi: 8,263
