Salta al contenuto principale
PlayStation Vita Right Shoulder Button Replacement
Cosa ti serve
  1. PlayStation Vita Right Shoulder Button Replacement, Case Separation: passo 1, immagine 1 di 2 PlayStation Vita Right Shoulder Button Replacement, Case Separation: passo 1, immagine 2 di 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Right Shoulder Button Replacement: passo 2, immagine 1 di 3 PlayStation Vita Right Shoulder Button Replacement: passo 2, immagine 2 di 3 PlayStation Vita Right Shoulder Button Replacement: passo 2, immagine 3 di 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Right Shoulder Button Replacement: passo 3, immagine 1 di 2 PlayStation Vita Right Shoulder Button Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Right Shoulder Button Replacement: passo 4, immagine 1 di 3 PlayStation Vita Right Shoulder Button Replacement: passo 4, immagine 2 di 3 PlayStation Vita Right Shoulder Button Replacement: passo 4, immagine 3 di 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Right Shoulder Button Replacement: passo 5, immagine 1 di 2 PlayStation Vita Right Shoulder Button Replacement: passo 5, immagine 2 di 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Right Shoulder Button Replacement: passo 6, immagine 1 di 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Right Shoulder Button Replacement: passo 7, immagine 1 di 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Right Shoulder Button Replacement: passo 8, immagine 1 di 1
    • Separate the front and rear cases.
  9. PlayStation Vita Right Shoulder Button Replacement, Wireless Card: passo 9, immagine 1 di 3 PlayStation Vita Right Shoulder Button Replacement, Wireless Card: passo 9, immagine 2 di 3 PlayStation Vita Right Shoulder Button Replacement, Wireless Card: passo 9, immagine 3 di 3
    • Using the pointy end of the spudger, disconnect the three antenna cable connectors on top of the wireless card.
    • Deroute the antenna cables so that they are out of the wireless card casing. Rest the wires out of the way.
  10. PlayStation Vita Right Shoulder Button Replacement: passo 10, immagine 1 di 2 PlayStation Vita Right Shoulder Button Replacement: passo 10, immagine 2 di 2
    • Hook the spudger beneath the tab on the wireless card casing and release the tab.
    • Peel up and remove the wireless card casing.
  11. PlayStation Vita Right Shoulder Button Replacement: passo 11, immagine 1 di 2 PlayStation Vita Right Shoulder Button Replacement: passo 11, immagine 2 di 2
    • Remove the two 4.4mm Phillips #00 screws on the wireless card.
    • The wireless card will naturally pop out at an angle.
    • Pull out the wireless card.
  12. PlayStation Vita Right Shoulder Button Replacement, Right Shoulder Button: passo 12, immagine 1 di 3 PlayStation Vita Right Shoulder Button Replacement, Right Shoulder Button: passo 12, immagine 2 di 3 PlayStation Vita Right Shoulder Button Replacement, Right Shoulder Button: passo 12, immagine 3 di 3
    • Pry up the right shoulder button casing with a spudger and set it aside.
  13. PlayStation Vita Right Shoulder Button Replacement: passo 13, immagine 1 di 1
    • Remove the translucent, plastic right shoulder button cover.
  14. PlayStation Vita Right Shoulder Button Replacement: passo 14, immagine 1 di 3 PlayStation Vita Right Shoulder Button Replacement: passo 14, immagine 2 di 3 PlayStation Vita Right Shoulder Button Replacement: passo 14, immagine 3 di 3
    • Release the right shoulder button flex cable socket by using a spudger to gently pry open the tab.
    • Using tweezers, slide the flex cable out of the socket.
  15. PlayStation Vita Right Shoulder Button Replacement: passo 15, immagine 1 di 2 PlayStation Vita Right Shoulder Button Replacement: passo 15, immagine 2 di 2
    • Using a spudger, gently peel up the right shoulder button from the light adhesive connecting it to casing.
Conclusione
Altre 3 persone hanno completato questa guida.
Brittany McCrigler
Membro da: 03/05/12
87.964 Reputazione
132 Guide realizzate
iFixit Membro di iFixit
Community
138 Membri
16.975 Guide realizzate
5 Commenti
Is anyone else experiencing the button getting stuck?
Fantasy Silicone Statuettes - Replica
Yes, mine is getting stuck, too. I am hoping a replacement will solve this problem.
aseelau -
Has anyone experienced or seen an issue where the trigger button acts with the same functionality as the home button. Every time I press the right trigger it exits to home or exits the game.....help please
Daniel - Replica
I followed this guide on my 3G vita in order to replace the right trigger cable. I found it wasn't necessary to remove the wireless card if anyone else finds that part tricky.
Caleb - Replica
i am replacing the whole front part of my vita do to screen cracked and wont turn on, when i put the button back on, how would i do so to make it stick back on? would i need to reglue it or will it stick back on by itself?
Saul Calderon - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 8
Ultimi 7 Giorni: 58
Ultimi 30 Giorni: 208
Tutti i Tempi: 12,776
