Salta al contenuto principale
PlayStation Vita Rear Panel Replacement
Cosa ti serve
  1. PlayStation Vita Rear Panel Replacement, Case Separation: passo 1, immagine 1 di 2 PlayStation Vita Rear Panel Replacement, Case Separation: passo 1, immagine 2 di 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Rear Panel Replacement: passo 2, immagine 1 di 3 PlayStation Vita Rear Panel Replacement: passo 2, immagine 2 di 3 PlayStation Vita Rear Panel Replacement: passo 2, immagine 3 di 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Rear Panel Replacement: passo 3, immagine 1 di 2 PlayStation Vita Rear Panel Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Rear Panel Replacement: passo 4, immagine 1 di 3 PlayStation Vita Rear Panel Replacement: passo 4, immagine 2 di 3 PlayStation Vita Rear Panel Replacement: passo 4, immagine 3 di 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Rear Panel Replacement: passo 5, immagine 1 di 2 PlayStation Vita Rear Panel Replacement: passo 5, immagine 2 di 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita Rear Panel Replacement: passo 6, immagine 1 di 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Rear Panel Replacement: passo 7, immagine 1 di 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita Rear Panel Replacement: passo 8, immagine 1 di 1
    • Separate the front and rear cases.
  9. PlayStation Vita Rear Panel Replacement, Battery: passo 9, immagine 1 di 2 PlayStation Vita Rear Panel Replacement, Battery: passo 9, immagine 2 di 2
    • With the help of a spudger, gently pry off and remove the battery cable retainer on the back casing assembly.
    • The easiest access to the battery cable retainer is where the battery cable comes out.
    • You can also use the two small tabs on the side of the cable retainer. Locate the tabs and release one at a time. Be a little careful not to push the cover in and re-lock it.
  10. PlayStation Vita Rear Panel Replacement: passo 10, immagine 1 di 2 PlayStation Vita Rear Panel Replacement: passo 10, immagine 2 di 2
    • Using a Phillips #00 screwdriver, remove the two 5.0mm blue battery case screws.
    • Remove the plastic battery retaining bar.
  11. PlayStation Vita Rear Panel Replacement: passo 11, immagine 1 di 3 PlayStation Vita Rear Panel Replacement: passo 11, immagine 2 di 3 PlayStation Vita Rear Panel Replacement: passo 11, immagine 3 di 3
    • Using your finger or a spudger, lift the battery out and remove it.
    • Guide the battery wires through the hole in the back casing as you remove the battery.
  12. PlayStation Vita Rear Panel Replacement, Rear Panel: passo 12, immagine 1 di 3 PlayStation Vita Rear Panel Replacement, Rear Panel: passo 12, immagine 2 di 3 PlayStation Vita Rear Panel Replacement, Rear Panel: passo 12, immagine 3 di 3
    • Slide the spuder between the right speaker and the rear casing.
    • Using a spudger, gently peel up the right speaker from the light adhesive connecting it to casing.
    • Remove the right speaker.
  13. PlayStation Vita Rear Panel Replacement: passo 13, immagine 1 di 3 PlayStation Vita Rear Panel Replacement: passo 13, immagine 2 di 3 PlayStation Vita Rear Panel Replacement: passo 13, immagine 3 di 3
    • Slide the spudger between the left speaker and the rear casing.
    • Using a spudger, gently peel up the left speaker from the light adhesive connecting it to casing.
    • Remove the left speaker.
  14. PlayStation Vita Rear Panel Replacement: passo 14, immagine 1 di 1
    • The rear panel remains.
Conclusione
Altre 11 persone hanno completato questa guida.
Brittany McCrigler
Membro da: 03/05/12
89.017 Reputazione
131 Guide realizzate
iFixit Membro di iFixit
Staff
135 Membri
16.817 Guide realizzate
5 Commenti
I really enjoyed Your article ! I'm about to replace the touch pad, i got a Vita recently but it has some Heavy scuffs. I've seen the back touch pad has adhesive attached on it. I bought a replacement On Ebay. I'm not sure if the replacement has adhesive with it. If it doesn't what would be your guys Thoughts on what i should use?
Daniel - Replica
lol you will need some kind of adhesive its called common sense if Sony use it you use it simple
TH3ORY -
I can't get pass Step 1. I can take out the bottom left screw of the rear touchpad but I can't take out the other 3. I bought a used Vita and there is a screw that turns but does not gout up. What should I do?
kken07655 - Replica
In the part that remains after complete disassembly, what are the two double pins at the top for, which later come into contact with the motherboard? I already have a new panel, but it has absolutely nothing except this one contact in the lower right part ...
Kamil Dębiec - Replica
Those are wifi antennas. You can get it out put it in to the new panel.
repairguy69 -
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 14
Ultimi 7 Giorni: 80
Ultimi 30 Giorni: 342
Tutti i Tempi: 30,332
