Salta al contenuto principale
PlayStation Vita Left Button Board Replacement
Cosa ti serve
  1. PlayStation Vita Left Button Board Replacement, Case Separation: passo 1, immagine 1 di 2 PlayStation Vita Left Button Board Replacement, Case Separation: passo 1, immagine 2 di 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita Left Button Board Replacement: passo 2, immagine 1 di 3 PlayStation Vita Left Button Board Replacement: passo 2, immagine 2 di 3 PlayStation Vita Left Button Board Replacement: passo 2, immagine 3 di 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita Left Button Board Replacement: passo 3, immagine 1 di 2 PlayStation Vita Left Button Board Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita Left Button Board Replacement: passo 4, immagine 1 di 3 PlayStation Vita Left Button Board Replacement: passo 4, immagine 2 di 3 PlayStation Vita Left Button Board Replacement: passo 4, immagine 3 di 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita Left Button Board Replacement: passo 5, immagine 1 di 2 PlayStation Vita Left Button Board Replacement: passo 5, immagine 2 di 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
    One of the shoulder buttons fell out when I was doing this step, along with the piece holding it in place. They go back in just fine when reassembling but make sure that they are oriented properly, of course.
    klung - Replica
  6. PlayStation Vita Left Button Board Replacement: passo 6, immagine 1 di 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita Left Button Board Replacement: passo 7, immagine 1 di 1
    • Free the battery cable by gently prying up on the connection with a spudger.
    Any idea what type of pcb header is on the board for the battery? I have a motherboard with a broken header but I cant source a replacement
    Jimbo Jones - Replica
    This is where I screwed up so I recommend extra caution for other newbies. Only the black part is supposed to come off. Don't be an idiot like me and pry off too much...
    ylimakiminna - Replica
    Yea I messed up there too. Is there a way to fix it?
    Alethia Henry - Replica
    This component was far more stubborn than the screen connector when it came to removal. I opted for a smaller tool than the spudger (small flat-head) and managed to disconnect it after determining the best bit size for the job. Screwdriver is metal, obviously, so being gentle helps to avoid damaging anything.
    klung - Replica
  8. PlayStation Vita Left Button Board Replacement: passo 8, immagine 1 di 1
    • Separate the front and rear cases.
  9. PlayStation Vita Left Button Board Replacement, Left Shoulder Button: passo 9, immagine 1 di 3 PlayStation Vita Left Button Board Replacement, Left Shoulder Button: passo 9, immagine 2 di 3 PlayStation Vita Left Button Board Replacement, Left Shoulder Button: passo 9, immagine 3 di 3
    • Pry up the left shoulder button casing with a spudger.
    • Remove the left shoulder button casing.
  10. PlayStation Vita Left Button Board Replacement: passo 10, immagine 1 di 2 PlayStation Vita Left Button Board Replacement: passo 10, immagine 2 di 2
    • Remove the translucent, plastic left shoulder button cover.
  11. PlayStation Vita Left Button Board Replacement: passo 11, immagine 1 di 3 PlayStation Vita Left Button Board Replacement: passo 11, immagine 2 di 3 PlayStation Vita Left Button Board Replacement: passo 11, immagine 3 di 3
    • Release the left shoulder button flex cable socket by using a spudger to pry open the tab.
    • Be careful to not break off this small black tab!
    • Using tweezers, slide the flex cable out of the socket. Do not pull on the black tab! Instead, pull the thin flex cable away from the connector (to the left in this image).
  12. PlayStation Vita Left Button Board Replacement: passo 12, immagine 1 di 2 PlayStation Vita Left Button Board Replacement: passo 12, immagine 2 di 2
    • Using a spudger, gently peel up the left shoulder button from the light adhesive connecting it to casing.
    This step is unneccesary.
    Alexander Mayatsky - Replica
  13. PlayStation Vita Left Button Board Replacement, Left Button Board: passo 13, immagine 1 di 2 PlayStation Vita Left Button Board Replacement, Left Button Board: passo 13, immagine 2 di 2
    • Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
    • Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
    Este paso NO es necesario si tu PSVita no tiene lector de tarjeta SIM. Ve directamente al paso 15.
    Parappa The Rapper - Replica
  14. PlayStation Vita Left Button Board Replacement: passo 14, immagine 1 di 3 PlayStation Vita Left Button Board Replacement: passo 14, immagine 2 di 3 PlayStation Vita Left Button Board Replacement: passo 14, immagine 3 di 3
    • Use a spudger to release the tab between the SIM card reader and the back casing assembly.
    • Lift the SIM card reader off the back casing assembly.
    This board is not present in the Wifi only version, only the 3G/Wifi version.
    dodo - Replica
  15. PlayStation Vita Left Button Board Replacement: passo 15, immagine 1 di 2 PlayStation Vita Left Button Board Replacement: passo 15, immagine 2 di 2
    • Release the plastic tab on the small flex cable socket by prying it up with a spudger.
    • Using tweezers, gently remove the small flex cable from the socket, and rest it out of the way.
  16. PlayStation Vita Left Button Board Replacement: passo 16, immagine 1 di 2 PlayStation Vita Left Button Board Replacement: passo 16, immagine 2 di 2
    • Use a spudger to lift up the tab on the large ZIF socket.
    • Gently pull the flex cable out of the ZIF socket, and rest it out of the way.
  17. PlayStation Vita Left Button Board Replacement: passo 17, immagine 1 di 2 PlayStation Vita Left Button Board Replacement: passo 17, immagine 2 di 2
    • Disconnect the white Wi-Fi antenna cable with a spudger.
    • Remove the Wi-Fi antenna cable.
    This connector isn't present in the Wifi only version, just the 3G/Wifi version.
    dodo - Replica
  18. PlayStation Vita Left Button Board Replacement: passo 18, immagine 1 di 3 PlayStation Vita Left Button Board Replacement: passo 18, immagine 2 di 3 PlayStation Vita Left Button Board Replacement: passo 18, immagine 3 di 3
    • Using a Phillips #00 screwdriver, remove the six screws on the two metal brackets:
    • Two 5.0mm, blue screws on the L-bracket securing the upper left button board to the motherboard.
    • Four 5.0mm, blue screws on the square bracket securing the lower left button board to the motherboard.
    What is the loose looking cable in this photo?
    Dallon Verhaeghe - Replica
  19. PlayStation Vita Left Button Board Replacement: passo 19, immagine 1 di 3 PlayStation Vita Left Button Board Replacement: passo 19, immagine 2 di 3 PlayStation Vita Left Button Board Replacement: passo 19, immagine 3 di 3
    • Starting from the upper left corner, use a spudger to pry up and remove the left button board.
Conclusione
Altre 6 persone hanno completato questa guida.
Brittany McCrigler
Membro da: 03/05/12
88.229 Reputazione
132 Guide realizzate
iFixit Membro di iFixit
Community
141 Membri
17.568 Guide realizzate
3 Commenti
good idea but i need help with the big fat one on the left because it went into water by an accsident and its not moving and its like locked or like jammed. I put it in the boiler for a while and i took it out after then it still was jammed locked.
Morganstutte@hotmail.com - Replica
please can you tell me how to fix the big fat button on the left because water went in it and i tryed putting it in the boiler for a while then i took it out and the button was still not working it like jammed locked it dosn't work. PLEEEEEEAAAAASSSSEEE HEEELLLPPP MEEEEEE!!!!!!!!!!!!!!!!!!
Make a video of it please!!!!
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 6
Ultimi 7 Giorni: 20
Ultimi 30 Giorni: 96
Tutti i Tempi: 8,689
