Introduzione
This guide takes you through installing the directional pad (D-Pad) on the PlayStation Vita.
Cosa ti serve
Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
Pry up the left shoulder button casing with a spudger.
Remove the left shoulder button casing.
Using a spudger, lift and release the tab on the ZIF socket sitting on the SIM card reader.
Carefully pull the flex cable out of the ZIF socket, and rest it out of the way.
Altre 9 persone hanno completato questa guida.
Un commento
I read this guide from the first to the20th step I haven't tried it yet though
