Salta al contenuto principale
PlayStation Vita 3G Antenna Cable Replacement
Cosa ti serve
  1. PlayStation Vita 3G Antenna Cable Replacement, Case Separation: passo 1, immagine 1 di 2 PlayStation Vita 3G Antenna Cable Replacement, Case Separation: passo 1, immagine 2 di 2
    • Power off and remove the memory card.
    • Using a Phillips #00 screwdriver, remove the four 6.4mm screws on the back casing.
  2. PlayStation Vita 3G Antenna Cable Replacement: passo 2, immagine 1 di 3 PlayStation Vita 3G Antenna Cable Replacement: passo 2, immagine 2 di 3 PlayStation Vita 3G Antenna Cable Replacement: passo 2, immagine 3 di 3
    • Using your fingernail or a spudger, pry open the accessory port cover on the top of the device.
    • Using a Phillips #00 screwdriver, remove the two 5.4mm screws hidden beneath the accessory port cover.
  3. PlayStation Vita 3G Antenna Cable Replacement: passo 3, immagine 1 di 2 PlayStation Vita 3G Antenna Cable Replacement: passo 3, immagine 2 di 2
    • Remove the two 5.4mm Phillips #00 screws on the bottom of the device near the charging port.
  4. PlayStation Vita 3G Antenna Cable Replacement: passo 4, immagine 1 di 3 PlayStation Vita 3G Antenna Cable Replacement: passo 4, immagine 2 di 3 PlayStation Vita 3G Antenna Cable Replacement: passo 4, immagine 3 di 3
    • Beginning at the sides of the device, use a plastic opening tool to separate the front and rear cases.
    • Continue working your way around the device gently prying it open.
    • There are still wires holding the front and rear cases together. You may damage the connections if you yank the cases completely apart.
  5. PlayStation Vita 3G Antenna Cable Replacement: passo 5, immagine 1 di 2 PlayStation Vita 3G Antenna Cable Replacement: passo 5, immagine 2 di 2
    • Gently separate the two cases, minding the battery and the touch screen controller connectors holding the two cases together.
  6. PlayStation Vita 3G Antenna Cable Replacement: passo 6, immagine 1 di 1
    • Using a spudger, free the touch screen controller flex cable by gently prying up the connection.
  7. PlayStation Vita 3G Antenna Cable Replacement: passo 7, immagine 1 di 1
    • Free the battery cable by gently prying up on the connection with a spudger.
  8. PlayStation Vita 3G Antenna Cable Replacement: passo 8, immagine 1 di 1
    • Separate the front and rear cases.
  9. PlayStation Vita 3G Antenna Cable Replacement, 3G Antenna Cable: passo 9, immagine 1 di 1
    • Using the pointy end of a spudger, gently pry the 3G antenna cable off of the wireless card.
  10. PlayStation Vita 3G Antenna Cable Replacement: passo 10, immagine 1 di 1
    • Using the pointy end of a spudger, gently pry the 3G antenna cable off the right button board.
    • Deroute the 3G antenna cable out of the casing and remove it.
Conclusione
Altre 2 persone hanno completato questa guida.
Brittany McCrigler
Membro da: 03/05/12
88.000 Reputazione
132 Guide realizzate
iFixit Membro di iFixit
Community
137 Membri
17.047 Guide realizzate
Un commento
I need mine fixed because it has came out but it isn’t a wire it is like a orange thin thing and it won’t clip back in
Jacob Gaming videos 123 - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 9
Ultimi 30 Giorni: 51
Tutti i Tempi: 7,136
