Salta al contenuto principale
PlayStation VR Headset Lenses Replacement
Cosa ti serve
  1. PlayStation VR Headset Lenses Replacement, LED Light Tracker: passo 1, immagine 1 di 3 PlayStation VR Headset Lenses Replacement, LED Light Tracker: passo 1, immagine 2 di 3 PlayStation VR Headset Lenses Replacement, LED Light Tracker: passo 1, immagine 3 di 3
    • Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
  2. PlayStation VR Headset Lenses Replacement: passo 2, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 2, immagine 2 di 2
    • Unscrew four 13 mm screws with a PH #000 screwdriver.
  3. PlayStation VR Headset Lenses Replacement: passo 3, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
  4. PlayStation VR Headset Lenses Replacement: passo 4, immagine 1 di 3 PlayStation VR Headset Lenses Replacement: passo 4, immagine 2 di 3 PlayStation VR Headset Lenses Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to pry the top white plastic panel free from the headset.
    • Do not try to remove the bottom plastic panel. There is a screw attaching it that must be removed first.
    • There may be a small amount of adhesive attaching the top panel to the headset, in which case you may need to use a bit more force to remove the panel.
  5. PlayStation VR Headset Lenses Replacement: passo 5, immagine 1 di 1
    • Flip the headset over.
    • Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
  6. PlayStation VR Headset Lenses Replacement: passo 6, immagine 1 di 3 PlayStation VR Headset Lenses Replacement: passo 6, immagine 2 di 3 PlayStation VR Headset Lenses Replacement: passo 6, immagine 3 di 3
    • Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
    • There is adhesive attaching the panel to the headset, in which case it will take more force to remove the panel.
  7. PlayStation VR Headset Lenses Replacement: passo 7, immagine 1 di 3 PlayStation VR Headset Lenses Replacement: passo 7, immagine 2 di 3 PlayStation VR Headset Lenses Replacement: passo 7, immagine 3 di 3
    • Unscrew the two 7 mm screws from the top of the headset.
  8. PlayStation VR Headset Lenses Replacement: passo 8, immagine 1 di 3 PlayStation VR Headset Lenses Replacement: passo 8, immagine 2 di 3 PlayStation VR Headset Lenses Replacement: passo 8, immagine 3 di 3
    • Using your fingers, carefully pry the black front panel free from the headset.
    • We recommend that you start the removal from the sides by pulling them forward.
    • There is adhesive holding the front panel in place, which means you will need a bit of extra force to remove it.
  9. PlayStation VR Headset Lenses Replacement: passo 9, immagine 1 di 1
    • Unscrew the four silver 6 mm screws in each corner using a PH #000 screwdriver.
  10. PlayStation VR Headset Lenses Replacement: passo 10, immagine 1 di 3 PlayStation VR Headset Lenses Replacement: passo 10, immagine 2 di 3 PlayStation VR Headset Lenses Replacement: passo 10, immagine 3 di 3
    • Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
    • Carefully pull the end of the white ribbon connector from its slot.
    • Be careful not to damage or dirty the ribbon connector.
  11. PlayStation VR Headset Lenses Replacement: passo 11, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 11, immagine 2 di 2
    • Unhitch the yellow led connector ribbon and move it aside.
  12. PlayStation VR Headset Lenses Replacement: passo 12, immagine 1 di 3 PlayStation VR Headset Lenses Replacement: passo 12, immagine 2 di 3 PlayStation VR Headset Lenses Replacement: passo 12, immagine 3 di 3
    • Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
    • Remove the yellow LED ribbons and black plastic connecting piece from the headset.
  13. PlayStation VR Headset Lenses Replacement, Headset Lenses: passo 13, immagine 1 di 2 PlayStation VR Headset Lenses Replacement, Headset Lenses: passo 13, immagine 2 di 2
    • Using the tweezers, unplug the three (one black bundled, two multi colored bundled) connector cables from their ports along the circuit board.
  14. PlayStation VR Headset Lenses Replacement: passo 14, immagine 1 di 1
    • Unscrew the two 7 mm screws near the lenses with a PH #000 screwdriver.
  15. PlayStation VR Headset Lenses Replacement: passo 15, immagine 1 di 3 PlayStation VR Headset Lenses Replacement: passo 15, immagine 2 di 3 PlayStation VR Headset Lenses Replacement: passo 15, immagine 3 di 3
    • Flip the headset back over.
    • With your fingers, carefully pry the top black plastic panel free.
  16. PlayStation VR Headset Lenses Replacement: passo 16, immagine 1 di 1
    • Unscrew one silver 4 mm screw from the white plastic band connecting the rest of the headset.
    • One 4 mm screw with a PH #000 screwdriver.
    • Even though there are two, only one of the silver screws needs to be unscrewed.
  17. PlayStation VR Headset Lenses Replacement: passo 17, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 17, immagine 2 di 2
    • Move the top black wires aside.
  18. PlayStation VR Headset Lenses Replacement: passo 18, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 18, immagine 2 di 2
    • Using a finger, press the black plastic tab up to loosen the white connector piece.
    • Slide the white plastic connector piece back and lift up to remove it.
  19. PlayStation VR Headset Lenses Replacement: passo 19, immagine 1 di 1
    • Unscrew the five silver 6 mm screws from the circuit board.
    • Five 6 mm scews with a PH #000 screwdriver.
  20. PlayStation VR Headset Lenses Replacement: passo 20, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 20, immagine 2 di 2
    • Using your fingers, lift up on the sides of the black plastic piece holding the circuit board in place.
    • There are small plastic tabs on the side that latch the piece in place that need to be lifted in order to remove it.
  21. PlayStation VR Headset Lenses Replacement: passo 21, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 21, immagine 2 di 2
    • Carefully lift the circuit board out of the headset and set aside.
    • Take care not to touch the screen.
  22. PlayStation VR Headset Lenses Replacement: passo 22, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 22, immagine 2 di 2
    • Using a hairdryer (or heatlamp), warm the area around the lenses. This will help loosen them for removal.
  23. PlayStation VR Headset Lenses Replacement: passo 23, immagine 1 di 2 PlayStation VR Headset Lenses Replacement: passo 23, immagine 2 di 2
    • Using a glass cloth (or any cloth with soft fibers), carefully press on the lenses until they pop out of place.
Conclusione
Altre 26 persone hanno completato questa guida.
Sarah Shand
Membro da: 02/20/17
1.885 Reputazione
7 Guide realizzate
USF Tampa, Team S3-G1, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Membri
13 Guide realizzate
24 Commenti
Wow..this looks a lot harder than it should be. I bought my PSVR used and the lenses are kinda scuffed up, like the previous owner cleaned them with something not perfectly soft. I was hoping they’d come out easily from the front, but I guess that’s not the case. Thanks for the immensely difficult guide!
spharvey - Replica
Where to buy a lense?
Bgex - Replica
Yep, where to buy the lenses?
Vicente Carro - Replica
I damaged my lenses also, so again same question, where I can buy them?
estsnoopp - Replica
Where can i buy new lenses for the PSVR?
Maikel Verschuren - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 9
Ultimi 7 Giorni: 50
Ultimi 30 Giorni: 239
Tutti i Tempi: 39,964
