Salta al contenuto principale
PlayStation VR Display Replacement
Cosa ti serve
  1. PlayStation VR Display Replacement, LED Light Tracker: passo 1, immagine 1 di 3 PlayStation VR Display Replacement, LED Light Tracker: passo 1, immagine 2 di 3 PlayStation VR Display Replacement, LED Light Tracker: passo 1, immagine 3 di 3
    • Peel back the rubber covering around the lenses to remove the surrounding plastic eyepieces.
  2. PlayStation VR Display Replacement: passo 2, immagine 1 di 2 PlayStation VR Display Replacement: passo 2, immagine 2 di 2
    • Unscrew four 13 mm screws with a PH #000 screwdriver.
  3. PlayStation VR Display Replacement: passo 3, immagine 1 di 2 PlayStation VR Display Replacement: passo 3, immagine 2 di 2
    • Using the plastic opening tool, carefully pry the white plastic panel free from the side of the headset. Repeat this action for the opposite side.
  4. PlayStation VR Display Replacement: passo 4, immagine 1 di 3 PlayStation VR Display Replacement: passo 4, immagine 2 di 3 PlayStation VR Display Replacement: passo 4, immagine 3 di 3
    • Use the plastic opening tool to pry the top white plastic panel free from the headset.
    • Do not try to remove the bottom plastic panel. There is a screw attaching it that must be removed first.
    • There may be a small amount of adhesive attaching the top panel to the headset, in which case you may need to use a bit more force to remove the panel.
  5. PlayStation VR Display Replacement: passo 5, immagine 1 di 1
    • Flip the headset over.
    • Using a PH #000, unscrew the 7 mm screw found on the bottom of the headset.
  6. PlayStation VR Display Replacement: passo 6, immagine 1 di 3 PlayStation VR Display Replacement: passo 6, immagine 2 di 3 PlayStation VR Display Replacement: passo 6, immagine 3 di 3
    • Using the plastic opening tool, pry the bottom white plastic panel loose and remove it from the headset.
    • There is adhesive attaching the panel to the headset, in which case it will take more force to remove the panel.
  7. PlayStation VR Display Replacement: passo 7, immagine 1 di 3 PlayStation VR Display Replacement: passo 7, immagine 2 di 3 PlayStation VR Display Replacement: passo 7, immagine 3 di 3
    • Unscrew the two 7 mm screws from the top of the headset.
  8. PlayStation VR Display Replacement: passo 8, immagine 1 di 3 PlayStation VR Display Replacement: passo 8, immagine 2 di 3 PlayStation VR Display Replacement: passo 8, immagine 3 di 3
    • Using your fingers, carefully pry the black front panel free from the headset.
    • We recommend that you start the removal from the sides by pulling them forward.
    • There is adhesive holding the front panel in place, which means you will need a bit of extra force to remove it.
  9. PlayStation VR Display Replacement: passo 9, immagine 1 di 1
    • Unscrew the four silver 6 mm screws in each corner using a PH #000 screwdriver.
  10. PlayStation VR Display Replacement: passo 10, immagine 1 di 3 PlayStation VR Display Replacement: passo 10, immagine 2 di 3 PlayStation VR Display Replacement: passo 10, immagine 3 di 3
    • Lift the small silver latch attaching the ZIF (zero insertion force) connector to the circuit board.
    • Carefully pull the end of the white ribbon connector from its slot.
    • Be careful not to damage or dirty the ribbon connector.
  11. PlayStation VR Display Replacement: passo 11, immagine 1 di 2 PlayStation VR Display Replacement: passo 11, immagine 2 di 2
    • Unhitch the yellow led connector ribbon and move it aside.
  12. PlayStation VR Display Replacement: passo 12, immagine 1 di 3 PlayStation VR Display Replacement: passo 12, immagine 2 di 3 PlayStation VR Display Replacement: passo 12, immagine 3 di 3
    • Carefully pry the black plastic piece attaching the yellow ribbon to the headset away from the green circuit board.
    • Remove the yellow LED ribbons and black plastic connecting piece from the headset.
  13. PlayStation VR Display Replacement, Motherboard: passo 13, immagine 1 di 1
    • Remove the two 6mm screws on the L shaped silver clip to the upper left of the motherboard using the Phillips #000 screwdriver.
    • Remove the one 6mm screw that is securing the silver clip on the far right side using the Phillips #000 screwdriver.
  14. PlayStation VR Display Replacement: passo 14, immagine 1 di 3 PlayStation VR Display Replacement: passo 14, immagine 2 di 3 PlayStation VR Display Replacement: passo 14, immagine 3 di 3
    • Remove the three 6mm screws from the motherboard using the Phillips #000 screwdriver.
    • Unplug the white cable and ribbons from the motherboard(make sure to lift the gates on the ribbons before pulling out).
    • Unplug the HDMI cable by lifting the gate and pulling gently(there will be adhesive).
  15. PlayStation VR Display Replacement: passo 15, immagine 1 di 1
    • Carefully remove the motherboard and place it on a hard dry surface.
  16. PlayStation VR Display Replacement, Display: passo 16, immagine 1 di 1
    • Press down firmly on the two clips on the sides of the device to remove the display.
    • If dust enters the display, it can impair function of the device.
  17. PlayStation VR Display Replacement: passo 17, immagine 1 di 1
    • Remove the four 6mm screws holding the display in place using the Phillips #000 screwdriver.
  18. PlayStation VR Display Replacement: passo 18, immagine 1 di 1
    • Carefully remove the display from the headset.
Conclusione
Altre 2 persone hanno completato questa guida.
Un commento
Where did you get the display that you replaced the first display with?
Junebug - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 3
Ultimi 7 Giorni: 11
Ultimi 30 Giorni: 64
Tutti i Tempi: 3,105
