Salta al contenuto principale
PlayStation VR Processor Unit Cooling Fan Replacement
Cosa ti serve
  1. PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: passo 1, immagine 1 di 3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: passo 1, immagine 2 di 3 PlayStation VR Processor Unit Cooling Fan Replacement, Processor Unit Cooling Fan: passo 1, immagine 3 di 3
    • On one side of the console (the side adjacent to the fan vent), there will be two 6 mm screws. Unscrew them with a PH #000 screwdriver.
  2. PlayStation VR Processor Unit Cooling Fan Replacement: passo 2, immagine 1 di 3 PlayStation VR Processor Unit Cooling Fan Replacement: passo 2, immagine 2 di 3 PlayStation VR Processor Unit Cooling Fan Replacement: passo 2, immagine 3 di 3
    • Press and slide the side panel (it will have the two ports) back to reveal an additional 6 mm screw.
    • Unscrew the 6mm screw with a PH #000 screwdriver.
  3. PlayStation VR Processor Unit Cooling Fan Replacement: passo 3, immagine 1 di 2 PlayStation VR Processor Unit Cooling Fan Replacement: passo 3, immagine 2 di 2
    • Slide the panel back into place.
  4. PlayStation VR Processor Unit Cooling Fan Replacement: passo 4, immagine 1 di 3 PlayStation VR Processor Unit Cooling Fan Replacement: passo 4, immagine 2 di 3 PlayStation VR Processor Unit Cooling Fan Replacement: passo 4, immagine 3 di 3
    • Using a plastic opening tool, carefully pry the panel from the main console to reveal the HDMI ports.
    • You will probably need to lift it on both sides in order for the panel to come loose.
  5. PlayStation VR Processor Unit Cooling Fan Replacement: passo 5, immagine 1 di 1
    • Turn the console over.
    • Unscrew the two 9 mm screws with a PH #000 screwdriver.
  6. PlayStation VR Processor Unit Cooling Fan Replacement: passo 6, immagine 1 di 2 PlayStation VR Processor Unit Cooling Fan Replacement: passo 6, immagine 2 di 2
    • With the plastic opening tool, carefully pry the console shell panel free and lift it away.
  7. PlayStation VR Processor Unit Cooling Fan Replacement: passo 7, immagine 1 di 2 PlayStation VR Processor Unit Cooling Fan Replacement: passo 7, immagine 2 di 2
    • Using tweezers, carefully pull the multi colored bundled cable from its port connecting the fan to the console.
    • Carefully lift the fan and its wiring from the device.
    • Be mindful of damaging the wires.
    • Take care to keep your fingers away from the fan blades.
Conclusione
Altre 8 persone hanno completato questa guida.
Sarah Shand
Membro da: 02/20/17
1.885 Reputazione
7 Guide realizzate
USF Tampa, Team S3-G1, Sullivan Spring 2017 Membro di USF Tampa, Team S3-G1, Sullivan Spring 2017
USFT-SULLIVAN-S17S3G1
3 Membri
13 Guide realizzate
4 Commenti
Where do I get a replacement fan tho?
Ponos King - Replica
I think is a 3x3 cm fan, alliexpres has some, but what voltage?
crus - Replica
5V is what i have read
Ethan Amos -
Reference for fan when I have replaced mine : DELTA ELECTRONICS MODEL : ASB0305MA-01 DC 5V 0.19A
herossuperman - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 15
Ultimi 30 Giorni: 50
Tutti i Tempi: 8,718
