Introduzione
Use this guide to replace the LED light on the Playstation Move
Cosa ti serve
Using a Phillips #0 screwdriver, remove the four 10mm screws located on the back of the device.
Insert tweezers between the LED case and the LED clear plastic cover.
Lift the edge of the LED clear cover clip to be able to remove the cover.
Repeat the previous step to the other side.
Remove the LED cover.
Altre 2 persone hanno completato questa guida.
3 Commenti
Okay, going to try this. Do I have to solder the white strip back onto the board?
did you ever get this done? need to know the same.
