Salta al contenuto principale
PlayStation Controller Ports Replacement
Cosa ti serve
  1. PlayStation Controller Ports Replacement, Open the Console: passo 1, immagine 1 di 1
    • Before you begin, make sure the console is turned off and unplugged.
    • Turn the console upside down and remove the five 15.8 mm-long Phillips #1 screws.
    The SCPH-9001 model does not have the Parallel Port panel to remove.
    Aislinn - Replica
  2. PlayStation Controller Ports Replacement: passo 2, immagine 1 di 2 PlayStation Controller Ports Replacement: passo 2, immagine 2 di 2
    • While holding the top and bottom halves of the console together, flip the console back over. Lift the top cover straight up to remove it.
  3. PlayStation Controller Ports Replacement, Remove the Controller Ports: passo 3, immagine 1 di 1
    • Remove five Phillips #1 screws securing the metal shield to the controller ports:
    • Two 14 mm screws
    • Three 8 mm screws
  4. PlayStation Controller Ports Replacement: passo 4, immagine 1 di 2 PlayStation Controller Ports Replacement: passo 4, immagine 2 di 2
    • Lift the metal shield straight up to remove it.
  5. PlayStation Controller Ports Replacement: passo 5, immagine 1 di 2 PlayStation Controller Ports Replacement: passo 5, immagine 2 di 2
    • Pull the controller port's ribbon cable straight up and out of its socket on the motherboard to disconnect it.
  6. PlayStation Controller Ports Replacement: passo 6, immagine 1 di 2 PlayStation Controller Ports Replacement: passo 6, immagine 2 di 2
    • Lift the controller ports straight up and out of the bottom case.
Conclusione
Altre 11 persone hanno completato questa guida.
Craig Lloyd
Membro da: 02/10/16
33.868 Reputazione
82 Guide realizzate
5 Commenti
I try replacing the controller and still wouldn't play memory cards.
redevil19 - Replica
I changed the controller port but the psx still doesn't recognize any controller. Both controller port and ribbon cable work perfect in other console. I wonder which components on the mother board are related with the controller ports so I can check them with a tester.
Daniel Prieto - Replica
I replaced the PS605 fuse and now the controllers work again! Thanks to this video https://www.youtube.com/watch?v=HdULot5F...
Daniel Prieto -
I'm having a weird issue, it will read in second do
Port but not the first. Changed controller port and still having the same issue
michael wise - Replica
The problem on mine is where I can’t use memory card slot 1 but Slot 2 works and is what I use but I would like to used slot 1 and have more than just a single memory card for playing games on it.
Travirus - Replica
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 5
Ultimi 7 Giorni: 40
Ultimi 30 Giorni: 139
Tutti i Tempi: 25,671
