Salta al contenuto principale
PlayStation Classic Controller Port Replacement
Cosa ti serve
  1. PlayStation Classic Controller Port Replacement, Motherboard: passo 1, immagine 1 di 1
    • Flip the console so its back is facing up.
  2. PlayStation Classic Controller Port Replacement: passo 2, immagine 1 di 1
    • Remove the five 3mm screws using the Phillips #00 screwdriver.
    • Make sure to keep your screws together in a secure location to avoid misplacement.
  3. PlayStation Classic Controller Port Replacement: passo 3, immagine 1 di 3 PlayStation Classic Controller Port Replacement: passo 3, immagine 2 di 3 PlayStation Classic Controller Port Replacement: passo 3, immagine 3 di 3
    • Remove the back plate from the rest of the console using your hands or the Jimmy tool.
  4. PlayStation Classic Controller Port Replacement: passo 4, immagine 1 di 1
    • Unscrew the motherboard's five 3mm screws with the Phillips #00 screwdriver.
    • Be careful not to apply too much force. The motherboard is flimsy and easy to break.
    • Keep track of your screws once they are removed.
  5. PlayStation Classic Controller Port Replacement: passo 5, immagine 1 di 3 PlayStation Classic Controller Port Replacement: passo 5, immagine 2 di 3 PlayStation Classic Controller Port Replacement: passo 5, immagine 3 di 3
    • Carefully remove the motherboard from the the rest of the console using your hands or the Jimmy tool.
  6. PlayStation Classic Controller Port Replacement: passo 6, immagine 1 di 3 PlayStation Classic Controller Port Replacement: passo 6, immagine 2 di 3 PlayStation Classic Controller Port Replacement: passo 6, immagine 3 di 3
    • The motherboard is connected to its metal protective casing with sticky pads. No tools are required to remove it.
    • Pull the metal casing off the motherboard.
    • Remember to be gentle when handling the motherboard.
  7. PlayStation Classic Controller Port Replacement, Controller Port: passo 7, immagine 1 di 2 PlayStation Classic Controller Port Replacement, Controller Port: passo 7, immagine 2 di 2
    • Identify the damaged or faulty controller port and simply use your fingers to remove.
Conclusione
Maxwell Webb
Membro da: 04/22/19
631 Reputazione
5 Guide realizzate
Cal Poly, Team S2-G8, Maness Spring 2019 Membro di Cal Poly, Team S2-G8, Maness Spring 2019
CPSU-MANESS-S19S2G8
2 Membri
22 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 1
Ultimi 7 Giorni: 8
Ultimi 30 Giorni: 33
Tutti i Tempi: 1,770
