Introduzione
Usa questa guida per rimuovere e sostituire la copertura inferiore in plastica della tua PlayStation 4 Slim.
Cosa ti serve
Trova l'adesivo di garanzia in plastica vicino alle tre porte sul lato della console.
Rimuovi l'adesivo di garanzia semplicemente staccandolo con qualsiasi tipo di spudger.
Svita e rimuovi la vite ora esposta da 5.0 mm usando un cacciavite di sicurezza T8 Torx con un movimento antiorario.
T8 fits like a glove for me
Is there anything else you can use
A small flathead screwdriver will work
There is a small metal rod in the middle of the screw that isn’t allowing my t8 inside. Any insight on this?
Some T8 bits have a hole in the middle that will allow that rod to go through; some do not. If you have a set of multiple bits, check if there are any others labeled T8 or TR8 with that hole in the middle.
Nicholas -
There is a metal thing inside of the screw slot any insite on this?
Gira la PlayStation 4 Slim sottosopra con il lato della vite rivolto verso di te.
Fai leva con le dita sui due angoli che sono rivolti verso di te.
Rimuovi la copertura inferiore facendola scorrere lontano da te e alzandola.
It says to place it upside down, but didn't you do so in the previous step? I've been trying to unscrew the screw with my screwdriver that I got from here and if I had to had the system right side up, I'm afraid I might've stripped the screw from all the force I tried to use to get the screw out that will NOT budge. It didn't even move the slightest after removing the warranty sticker.
There is a single clip on the left side about 5cms in, and another clip on the right side equidistant to the one on the other side. Jamming a spudger in there first, and lifting those clips helped, and then I had to slide down to lift a total of 4 clips on each side (each about 4cms apart). Then push the cover away from you, if that makes more sense than “sliding it towards the back corners”, since the back corners are technically facing you.
I saw many video and tried it my self, you have to remove the hard disc before removing any cover.
Per riassemblare il dispositivo, segui le istruzioni nell'ordine inverso.
Altre 36 persone hanno completato questa guida.
Un ringraziamento speciale a questi traduttori:
100%
Questi traduttori ci stanno aiutando ad aggiustare il mondo! Vuoi partecipare?
Inizia a tradurre ›
2 Commenti
Wo kann man die Bodenplatte kaufen?
Hi hello it's Good
Remove the screw directly to the left of that one in the picture as well. Should be silver.
Elizabeth Johnson - Replica
ihr seid so ein scheiß haufen das stimmt über haubt nix
Toaster 95 - Replica
einfach alles stimmt nicht
