Salta al contenuto principale
Introduzione
PREREQUISITE ONLY (to maintain smooth flow of guide)
  1. Flip the console upside down. Use your finger to pull and snap off the plastic cover over the hard drive. Use your finger to pull and snap off the plastic cover over the hard drive.
    • Flip the console upside down.
    • Use your finger to pull and snap off the plastic cover over the hard drive.
  2. Use a Phillips #0 Screwdriver to remove the single screw securing the hard drive caddy. Pull the hard drive caddy straight out.
    • Use a Phillips #0 Screwdriver to remove the single screw securing the hard drive caddy.
    • Pull the hard drive caddy straight out.
  3. Flip the console right side up. Grip the two corners located at the front of the device. Pull upwards until a loud click is heard.
    • Flip the console right side up.
    • Grip the two corners located at the front of the device.
    • Pull upwards until a loud click is heard.
    • This may require a lot of force, so do not be afraid to get a little rough with your console.
    • After both corners detach, slide the cover backwards and lift off.
  4. Use a T8 Torx Security screwdriver to remove five screws from the rear of the device. Two 31mm screws. Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Use a T8 Torx Security screwdriver to remove five screws from the rear of the device.
    • Two 31mm screws.
    • Three 10mm screws for the 7000 models; Two gray 10mm screws (upper and lower screws on the illustration) if the PS4 Pro is a 7100-series model.
    • Remove the metal plate by pulling it up.
  5. Flip the console over so the bottom is facing up. Use a T8 Torx Security  screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left. Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
    • Flip the console over so the bottom is facing up.
    • Use a T8 Torx Security screwdriver to remove the three black 7mm screws in the back panel. (7000-series models only); or one 7mm screw (the middle one) with 7100-series models and the warranty sticker to the left.
    • Remove the bottom cover in the same way as the top cover. Grip the cover on both sides and pull up until it clicks. Then slide the cover off; With 7100-series models, pay attention to the two clips that replace the corresponding screws.
  6. Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate. Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate. Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
    • Use a T8 Torx security screwdriver to remove the eleven 10mm silver screws from the metal plate.
    • Use a Phillips #1 screwdriver to remove the eleven 4mm black screws from the metal plate.
    • Use a spudger to disconnect the three antenna cables (two black and one white) by prying them straight up from their sockets.
  7. Pull the white fan connector straight out of the yellow mount on the motherboard. Pull the white fan connector straight out of the yellow mount on the motherboard.
    • Pull the white fan connector straight out of the yellow mount on the motherboard.
  8. Pull out the five small, blue low profile cables connected to the metal plate. Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull out the five small, blue low profile cables connected to the metal plate.
    • Lift the retaining flap on the ZIF connector of the large ribbon cable.
    • Pull the large ribbon cable from its socket.
    • Do not pull on the biggest blue cable without lifting the tab first. Doing so can damage the connection.
  9. Pull up and remove the metal plate.
    • Pull up and remove the metal plate.
  10. Flip the console over to continue working on the top side. Pull up on the power supply unit and set it on the console. Be careful not to pull too far, the assembly is still connected at one point.
    • Flip the console over to continue working on the top side.
    • Pull up on the power supply unit and set it on the console.
    • Be careful not to pull too far, the assembly is still connected at one point.
    • Grip the connector behind the power supply and pull straight out.
Conclusione
Thomas
Membro da: 26/04/2017
2.653 Reputazione
5 Guide realizzate
Cal Poly, Team S21-G5, Livingston Spring 2017 Membro di Cal Poly, Team S21-G5, Livingston Spring 2017
CPSU-LIVINGSTON-S17S21G5
4 Membri
39 Guide realizzate
0 Commenti
Aggiungi Commento
Visualizza Statistiche:
Ultime 24 Ore: 0
Ultimi 7 Giorni: 1
Ultimi 30 Giorni: 2
Tutti i Tempi: 281
