Introduzione
Use this guide to replace the circuit board responsible for Bluetooth and Wi-Fi connectivity.
Cosa ti serve
Use the tip of a spudger to remove the black rubber screw cover from the side of the PS3.
Remove the following seven screws:
Six 52 mm Phillips screws
One 30 mm Phillips screw
Lift the top cover from its rear edge and rotate it toward the front of the PS3.
Remove the top cover.
There is a plastic hook located in a hole on the top back right hand side corner. Carefully push the plastic hook a bit from the rear of the machine with a spudger to release the rear right of the casing.
Remove the two 9 mm Phillips screws securing the memory card reader to the chassis.
Altre 25 persone hanno completato questa guida.
4 Commenti
Note: Only the first 2 generations of PS3 fats have removable Wifi/BT cards. If you have a third generation fat (VER-100 motherboard or later) the Wifi/BT chips are integrated into the board and thereby NOT removable.
does anybody know how many pins there are on the data ribbon / flex cable of the Wifi / Bluetooth board and Card Reader in the 60gb Model? It would be a great help! Thanx
I have a PS3 Slim 2501b can I still use this technique to change my Bluetooth
No you can't
J P -
